Fuel tank
(Redirected from Sedan Fuel Tank)
Category: Fuel System
Datsun 1200 uses a 38 or 40 liter petrol (gasoline) tank.
Capacity
Mounting
Sedan tank is inside boot, just behind rear seat:
3527.jpgAlbum 3527 13984.jpgAlbum 13984 5627.jpgAlbum 5627
Coupe tank is underneath the car, under the boot area:
3528.jpgAlbum 3528 2134.jpgAlbum 2134
VB110 wagon tank
3529.jpgAlbum 3529
Truck tank
19621.jpgAlbum 19621
Gas Cap
Main: Fuel Cap
See also: Fuel Door
Fuel Sender
The fuel gauge level 'sender' is the sensor in the tank.
Return Line
Starting in 1975, North American B210s were fitted with a fuel return line. Here's what the Nissan publication "Introduction of Datsun B210 (1975 model)" says:
Fuel return system
For preventing abnormal fuel temperature rise, the fuel return system has been installed. In this system, fuel from the fuel tank is delivered to both the carburetor and fuel tank.
The fuel return line services to return a part of the fuel to the fuel tank to suit different engine operating requirements, preventing the possibility of fuel heated flowing through the fuel line inside the engine compartment, and elminating "percolation" inside the carburetor.
Thus the return line prevents vapor lock (engine stalling and engine hot-starting issues).
Venting
Datsun 1200 in most parts of the world vents the fuel tank to the atmosphere. A simple hose loop goes from the filler tube up above the tank and back down towards the ground. The loop is to prevent a siphoning effect.
3527.jpgAlbum 3527 3528.jpgAlbum 3528 3529.jpgAlbum 3529 174_5a67ad0e16321.jpgPost 487378
Van (wagon)
13022_4e3cba168ae1f.jpgPost 378698
EVAPO
In Australia after 1978, and Japan after 1974, and all years in North America 1200s used the Evaporative emissions control system.
With EVAPO, the tank is not vented directly to the air. Instead, fumes are captured by the Evaporate Emission control (EVAPO) system. For details, see Fume Control.
Filler Hose
Coupe
USA B110 coupe tank
18602.jpgAlbum 18602 18603.jpgAlbum 18603 18604.jpgAlbum 18604 18605.jpgAlbum 18605
JDM
16615.jpgAlbum 16615
Sedan
Note that the USA B110 sedan tank uses a 2-piece filler hose (there's a small hose inside the bigger one). This is for the EVAPO (emissions market) vehicles:
9715.jpgAlbum 9715
Two-piece curved filler hose for EVAPO system
This hose is NLA (No Longer Available) in US, Canada or Japan. However, the regular single hose can be fitted as follows:
9716.jpgAlbum 9716
Straight one-piece filler hose for non-EVAPO system
The hose looks like this:
9717.jpgAlbum 9717
Filler Hose Comparo
Filler Modifications
9718.jpgAlbum 9718 9719.jpgAlbum 9719 9720.jpgAlbum 9720
Discussion: POSTNeed Fuel Tank!!
Drain Plug
The tank has a very useful drain plug. It is a special M12 bolt that uses a crush washer. Possibly a normal M12 with large washer and drain pan style washer can be used.
08931-44210 PLUG M12 thread hex head
* Datsun 1200 wagon, sedan, coupe, truck
* Datsun 520 truck
* Datsun 620 truck
Sedan Tank
Early: ventless (vents through filler hose) up to chassis number B110-145650, B110-600010
17201-H1000 ASS'Y-TANK, fuel
17201-H1001 ASS'Y-TANK, fuel (with baffle plate) > 17201-H100
Revised: two tank vents
All PB110 sedan
B110 from chassis number B110-145651, B110-600011
* Fuel Sender updated at same time
17201-H1902 ASS'Y-TANK, fuel
17201-H2800 ASS'Y-TANK, fuel > 17201-H1902
17201-H2800 vented tank
174_5b349e013a668.jpgPost 488733 174_5b349e369ce2f.jpgPost 488733 174_5b349e59c453a.jpgPost 488733 174_5b349e640f27f.jpgPost 488733174_5b349e8c2d883.jpgPost 488733
Sedan Tank factory Baffling:
12328.jpgAlbum 12328
Coupe Tank
25547.jpgAlbum 25547 100_5192.jpg 100_5235.jpg 22649.jpgAlbum 22649
Vent hose loop
22648.jpgAlbum 22648
Vent hose loop (end hangs free, vents to atmosphere)
Fuel sender vents to filler hose
Fuel Outlet is on bottom half of tank
Fuel Outlet goes back
US EVAPO
Expansion Tank is a liquid/vapor separator. This was replaced by a check valve in the B210 sedan, while B210 coupe continued to use the separator tank. In the B310 this tank was removed and all models used the check valve.
17350-H1801 ASSY-TANK RESERVOIR
17350-H1802 ASSY-TANK RESERVOIR
20427.jpgAlbum 20427
22647.jpgAlbum 22647
Diagram
20428.jpgAlbum 20428
Truck Tank
17251-G1001 CAP ASS'Y-filler
17251-H1901 CAP ASS'Y-filler EVAPO 1973
174_5a67b2d182c96.jpgPost 487379
Fuel Door
19888.jpgAlbum 19888
10879.jpgAlbum 10879
EVAPO
Reservoir tanklet was added March 1973 in Japan.
1978 in Australia.
Ute_fuel_tank-reservoir-type.jpg 24465.jpgAlbum 24465
See also: Part Numbers
1987 (昭和62年1月)
174_5db015e41e70b.jpgPost 492942 174_5db015eee5e4d.jpgPost 492942 174_5db015f80450e.jpgPost 492942
Return line was added] October 1989 (see Truck_Fuel_Tank_Part_Numbers).
Late tank, 1989 October - 1994
TANK ASSY-RESERVE 17350-G1403, 17350-G1402
placed above main tank, up in the tray sidewall
25589.jpgAlbum 25589
13878.jpgAlbum 13878
B210 Sedan Tank is similar to B110 Sedan tank
6525_4ac8776c4dfe7.jpgPost 283008 6525_4ac877c96bb4e.jpgPost 283008
Compare to B110 SEDAN tank
3527.jpgAlbum 3527
B310
10691.jpgAlbum 10691
Parts Sources
  • Nissan. In North America, call Ericksen Nissan's toll-free number. If Ericksen says they can't get a part let us know (click "Edit" and add it to this article). Also, if they do get the part for you, let us know that too!
    • NOTE: Nissan USA is out of stock forever of the Sedan hose. But perhaps they can get the Coupe hose.
  • Wreckers, if you can find a 1200 in a wrecking yard
  • Friends with parts cars
  • Marine supply stores, for general fuel hose and filler hose. NAPA and other old-line auto parts store carry this generic fuel-rated hose also. Trimmed to length using the old filler hose as a guide. It is tough getting it to flex into shape, but can be done.
Alloy Tanks
Coupe
16475.jpgAlbum 16475
Ute
12039.jpgAlbum 12039 10257_4d44c8caae1cc.jpgPost 355072
Fuel Cell
See Main Article: Fuel cell
タンク ガソリン
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Fuel_tank"
This page has been accessed 89,817 times. This page was last modified 16:18, 9 March 2025. Content is available under Datsun 1200 Club.
