There is no page titled ":Specs". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- 5-Speeds (19568 bytes)
269: ...10‑H7220N</td><td valign=top bgcolor=F0F0F0>specs from [http://www.pitroad-ts.com/tuning-page/FS5W6... - Engine Swaps (25981 bytes)
508: = Engine weights and specs =
543: * Read discussion about how engine weight specs are varying (for example: Nissan RB engine weighs... - Strut Insert Part Numbers (10856 bytes)
51: == Stock Specs ==
178: Part number: 363001 is for australia specs are exactly same as 361005. - Ignition Timing (9164 bytes)
151: ...rence -- up to 4 degrees retarded is still within specs -- and is why you should tune your A12 for power. - Steering wheel (10037 bytes)
112: ...is made it unique, The B110 & B210 share the same specs so the hub/boss is interchangeable between these ... - Changing Head Gasket (9192 bytes)
92: = Other Tightening Torque specs = - Nissan B140 (13604 bytes)
143: 2007 Specs: - A-series Cylinder Heads (27757 bytes)
86: * 11041-H5703 GX cylinder head (from 7/73) same specs, but for newer engine style - Late-model Vacuum Advance (3498 bytes)
1: ...ts. See Datsun [[Factory Service Manual]] for the specs. Original B110 distributors use [[Distributor#Vac... - Weber DCOE carburetor (9502 bytes)
100: ...zon.com link]). It has this in the back. The B210 specs should be a good starting point for a stock A14. - 63-Series Transmission (11903 bytes)
58: ... 1978 B210 Service Manual (north america). It has specs, photos, diagrams and procedures. - VB110 (5815 bytes)
102: body alignment specs - 1972 Van Girl (2399 bytes)
49: back cover with Sunny Van 1200 Series specs (Super Deluxe, Deluxe, Standard) - Strut (11961 bytes)
101: Here are the specs for Datsun 1200 (B110) struts: - Repair Manual (20350 bytes)
241: *: Specs, Carb, tips etc. for 1200, 510 and 240-Z - Engine buildup (10548 bytes)
75: ...ock). This is measured on an engine dyno (Factory specs are *not* measured by rear-wheel-horsepower -- se... - Crankshaft (8631 bytes)
186: = Specs = - Oil pan (12365 bytes)
38: Specs - Brake Pads (9387 bytes)
17: Pad specs:
29: Pad specs:
45: Pad specs:
178: Specs:
209: Specs - KB10 (9097 bytes)
50: ...et DeLuxe model. Other states may have varied the specs a little but the Aussie spec car was better equip...
