Throttle Cable
From Datsun 1200 Club
Categories: Fuel System | Hitachi 306 Carburetor | Hitachi Twin Carb
Datsun 1200 uses a throttle cable with twisted-braid steel core. A cable is superior to linkage for smooth throttle action. RHD and LHD differ by length.
Also See: Accelerator Pedal
19261.jpgAlbum 19261
Ends
Both RHD and LHD use the same clip on the interior to fix the cable to the Accelerator Pedal.
Throttle Cable ball-end fits into slot on end of Accelerator Pedal. Usually a clip goes over the cable ball-end. But as long as the cable is properly adjusted you can drive it for years without the clip in place.
25874.jpgAlbum 25874
18036-18000 SPRING-CLAMP ACCELERATOR WIRE
* push-on clip fixes cable to accelerator pedal
25878.jpgAlbum 25878
Ferrule end (that clamps to the carburetor)
* 8mm diameter x 21mm long ALL
Cable
Since the carburetor is always on the same side, the accelerator cable length is different for RHD and LHD models.
When replacing, adjust cable for 1mm play at the carburetor cable clamp.
Left-Hand Drive
B110
A8200-G1300 ASSY-WIRE ACCELERATOR [40 mm length] $7.30 USD
* Superceded old part number 18200-H1600
B210: 18200-H7200 ASSY-WIRE ACCELERATOR A14 FED(GFU) From 12/76 $20.81 USD
B210: 18200-H6102 ASSY-WIRE ACCELERATOR $19.08 USD
* Superceded 18200-H6100
15318.jpgAlbum 15318
Length measured firewall to end of cable ferrule
* B110: 40 mm long ball-end
* B210: 43.5 mm long ball-end
* B310: 40 mm long eyelet-end
Right-Hand Drive
18200-H1000 WIRE ASS'Y-accelerator B110 [85 cm length, tube 72cm]
* 18211-18001 RING-wire clamp
18200-G1601 ASSY-WIRE ACCELERATOR B120 -8910
18201-95W00 ASSY-WIRE ACCELERATOR B120 8910-
* 24222-89901 CLIP-WIRE, ACCELERATOR 9810-
Other Part Numbers
RHD
18200-18000 WIRE ASS'Y-accelerator B10 superceded
18200-18001 WIRE ASS'Y-accelerator B10 replaces 18200-18000
18200-27700 WIRE ASS'Y-accelerator B10 replaces 18200-18001
18200-H5000 WIRE ASS'Y-ACCELERATOR B210 early
 * SBK SA-0227
18200-H5005 WIRE ASS'Y-ACCELERATOR B210 early GL op. and late B210
 * SBK SA-A225
18200-H5205 WIRE ASS'Y-ACCELERATOR B210 GX A12T
18200-H7510 WIRE ASS'Y-ACCELERATOR B210 A14T
18200-H7900 WIRE ASS'Y-ACCELERATOR B210 L16
18201-H8501 WIRE ASS'Y-ACCELERATOR B310
 * SBK SA-0229
18201-H8502 WIRE ASS'Y-ACCELERATOR B310 NLA
 * SBK SA-A220
18201-H9205 WIRE ASS'Y-ACCELERATOR B310 A14E, A15E
LHD
B210 18200-H7200 GFU
 * SBK EA-0224
B210 18200-H6100 <> 18200-H6102
 * SBK EA-0227, SBK EA-0228
 * PIONEER CA8610
   Overall length: 22"
   Mounting Length: 16"
 * BECK/ARNLEY 0950400
18201-H8802 USA/CAN WIRE ASSY-ACCEL Rockauto $11
 * PIONEER CA8825
   Overall Length 20.9" ?
   Mounting Length 16.1" ?
 * BECK/ARNLEY 0950403
 * TSK/Nippon Cable System 4PA1004
 * SBK EA-0229
18201-H9106 KFU
18201-H9160 CAL.MAN 0879-
 * PIONEER CA8826
Sunny Wire Co. for Datsun 310 - NOT for Sunny B310
車名    car name    DATSUN
部品番号  part number 310
品名    part name   ACCEL
GX Cable Routing
GX uses same cable as others RHD Datsun 1200s.
8355.jpgAlbum 8355
14540.jpgAlbum 14540
Also See: GX Linkage Part Numbers
Weber DGV Cable
See Main Article: Weber 32/36 Throttle Linkage
174_500335e2a5b3e.jpgUpload click to view
Sidedraft Cable
Also see:
* Weber_DCOE_carburetor#Linkage
* Mikuni_PHH#Linkage
* Dellorto DHLA
556.gifAlbum click to view 1113.jpgAlbum click to view 1114.jpgAlbum click to view 1115.jpgAlbum click to view 3422.jpgAlbum click to view 3461.jpgAlbum click to view 3503.jpgAlbum click to view 5212.jpgAlbum click to view 6581.jpgAlbum click to view 8988.jpgAlbum click to view 9463.jpgAlbum click to view 11368.jpgAlbum click to view 11497.jpgAlbum click to view 11506.jpgAlbum click to view
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Throttle_Cable"
This page has been accessed 27,005 times. This page was last modified 07:14, 16 August 2017. Content is available under Datsun 1200 Club.
