Main : Racing : Track Race Car Build Day 6 Carb Install
[<   Previous  289  290  291  292  293  294  295  Next   >]
Race Car Build Day 6 Carb InstallPopular
SubmitterconvertedMore Photos from converted   Last Update2004/4/28 8:26    Tell a friendTell a friend
Hits3434  Comments6    0.00 (0 votes)0.00 (0 votes)
Here are the twin Webers 40mm rebuilt by Jeff Taylor of JTS perfromance St Marys. It cost $525 including everything. The carbs wouldnt clean up with Autosol so a quick spray did the trick!! (I know its dodgey!!!) So far the total build including the car, carb rebuild, cage, front and rear suspension, and respray is around $3500. I estimate that I will have it will be finished for around $5000. I need a new seat as the old Stratos Ambulance seat will not conform to FIA and harnesses, baffled tank and front suspension and oil cooler will bring it up to that. If anyone has the above listed parts for sale please PM me.
teretonga
Posted: 2004/4/28 11:21  Updated: 2004/4/28 11:21
 Re: Race Car Build Day 6 Carb Install
This is schmicko Watto. I thought you needed a new seat because your huge glutes meant you were too heavy to be an ambulance driver?
kegs
Posted: 2004/4/28 14:12  Updated: 2004/4/28 14:12
very very nice, may i ask what paint u used for weber as i may copy hehe and did the lancer booster bolt up with no mods at all ive got the same one looks to go straight in ull be bale to tell as noone else knows.
B120dat
Posted: 2004/4/28 14:35  Updated: 2004/4/28 14:35
why is there holes in the metal heater hose?
evilsim
Posted: 2004/4/28 15:30  Updated: 2004/4/28 15:30
damn those webers look good ! metal polish doesnt work that well ure right but i found liquid mag cleaner worked pretty well. still couldnt get some of the dirt out of tight corners but it still came out better than before i cleaned em.
here here !! plz provide info
Razor
Posted: 2004/4/28 21:48  Updated: 2004/4/28 21:48
Looks tough!
that rocker cover oil cap looks unique...
its like the radiator cap
kegs
Posted: 2004/4/29 5:52  Updated: 2004/4/29 5:52
hhmmm wonder if they were the set of webers sittin on the floor when i went round there to put my engine in??? come on converted need info bout brake booster, does the arm that connects to the brakes just connect up no probs, and does the bolts on the firewall line up? sorry bout the questions but can u tell me how u plan to get the brake lines to connect????
