Main : Mechanical : Engine Turbo setup on a12
[<   Previous  2566  2567  2568  2569  2570  2571  2572  Next   >]
Turbo setup on a12
Turbo setup on a12Popular
Submitterchris1200tMore Photos from chris1200t   Last Update2005/3/16 12:02    Tell a friendTell a friend
Hits5162  Comments8    0.00 (0 votes)0.00 (0 votes)
Heres the setup with all the cyl's attached now i just have to hook up the carby and where all set.
chris1200t
Posted: 2005/3/21 8:38  Updated: 2005/3/21 8:38
 Re: Turbo setup on a12
I got the turbo started up last night i hooked up the carby and il take pics of that soon. iv only got one little problem and thats witht he carby because it starts to rev was to high and i gant get an idle with it if theres any suggestions please tell me.
120fly
Posted: 2005/3/19 10:01  Updated: 2005/3/19 10:01
Thanks rogue wasnt to sure on the exhaust side of things .. as for the hose , ive aquired some silicon hose they use on large boats which runs from the petrol filler to the tank ...this is rated to carry fuel and exhaust ..might help...might not...
120fly
Posted: 2005/3/16 13:53  Updated: 2005/3/16 13:53
have you hooked up the exhaust side yet ..What exhaust manifold are you using on this a12 ...hmm...seems like the intake would be better with standard manifold less dicen n slicen keep up the work matey BOOST is just around the corner ,,,,,,,,,,,,,,
A14force
Posted: 2005/3/17 7:16  Updated: 2005/3/17 7:16
I hope you are going to use silicon hose for your joins on the boost side.
Looks like lots of fun.
LAGWAGON
Posted: 2005/3/19 4:07  Updated: 2005/3/19 4:07
No need for the silicon, just look at the factory turbo setups on any late model car, they all use rubber bends. if a heater hose can take temps of 100+ degrees celcius, it'll be fine with the turbo intake temps, just keep them shielded from the manifolds. it is a budget build remember!
many have gotten to this stage before you tho, its getting it running and making it stay in one piece that is the hard part!!! good luck!
Rogue
Posted: 2005/3/19 5:07  Updated: 2005/3/19 5:07
Looks like the turbo is bolted straight up to the hole on top of the exhaust manifold (where it heats the original inlet manifold) and the carby mount section of the inlet manifold has been chopped out to make room for the turbo;Then 1-2 and 3-4 manifold sections have been swapped around to allow them to be spliced back together with rubber hose from the turbo.
A lot of thought has been invested in this set-up and even though it may seem a little crude, there is no reason why it should`nt work.
Good luck with your project
chris1200t
Posted: 2005/3/16 12:05  Updated: 2005/3/16 12:05
The carby that im using is a 2 inch su.
Cheers
phunkdoktaspok
Posted: 2005/3/16 12:20  Updated: 2005/3/16 12:20
Its interesting how you cut the inlet in 2 and swaped 1,2 cyls for 3,4 vise-versa.
What did you do with the exhaust manifold? did you block the outlet flange and just weld another flange in the middle for the turbo?
Demojob
Posted: 2005/3/16 12:37  Updated: 2005/3/16 12:37
thats not heater hose piping, I hope.......
