Main : Mechanical : Engine Nismo high ouput oil pump internals
[<   Previous  2506  2507  2508  2509  2510  2511  2512  Next   >]
Nismo high ouput oil pump internalsPopular
Submitterkb110More Photos from kb110   Last Update2005/3/21 5:16    Tell a friendTell a friend
Hits4530  Comments5    0.00 (0 votes)0.00 (0 votes)
The title says it all.......
kb110
Posted: 2005/3/21 11:31  Updated: 2005/3/21 11:31
Quite a regular
 Re: Nismo high ouput oil pump internals
I bought the darn thing in '74 (jeez, that ages me) and used it for a couple of years. It worked OK and had more pressure than a std pump.
It will live again and thanks for all the tips guys.........
A14force
Posted: 2005/3/21 7:47  Updated: 2005/3/21 7:47
I think you should give that to me!!!!!!
dattodevil
Posted: 2005/3/21 8:20  Updated: 2005/3/21 8:20
So you got it apart then john Its hard to see how this can pump so much more that the factory unit.
Dodgeman
Posted: 2005/3/21 9:02  Updated: 2005/3/21 9:02
Gear type pumps tend to be a problem if the oil drains away from the gears, They have difficulty "pulling" up the oil, which is why they are frequently seen in submerged applications.
Once the gears have oil, they work great, so it would pay to ensure the engine had pressure before firing it up after being in storage between race seasons.
L18_B110
Posted: 2005/3/21 11:16  Updated: 2005/3/21 11:16
if it has been a very long time since firing it up, it's good practice to remove the oil pump and grease those gears first to ensure it pumps effectively from the start. Same goes if you're rebuilding the engine.
