Main : Mechanical : Engine a12 turbo running and finished
[<   Previous  2563  2564  2565  2566  2567  2568  2569  Next   >]
a12 turbo running and finishedPopular
Submitterchris1200tMore Photos from chris1200t   Last Update2005/3/24 13:37    Tell a friendTell a friend
Hits4840  Comments5    0.00 (0 votes)0.00 (0 votes)
Here she is its not really finished i still kneed to tune the carby and hook up the exhust which ill be doing this weekend. i have more pics if u want them.
Cheers
datsun120ycoupe
Posted: 2005/12/11 4:43  Updated: 2005/12/11 4:43
 Re: a12 turbo running and finished
umm wheres the dump pipe, or where does it go
chris1200t
Posted: 2005/3/24 13:40  Updated: 2005/3/24 13:40
if anybody kows alot about tuning su carbs then tell us cause i kneed some info the carbs of an MG.
A14force
Posted: 2005/3/24 21:48  Updated: 2005/3/24 21:48
Good on you!
BUT, please replace the zip ties with hose clips. And, it must be a trick of the light, cos you haven't used clear nylon hose for your fuel line....Have you?
Frodaddy
Posted: 2005/7/7 0:48  Updated: 2005/7/7 0:48
Isn't that a 1.5" HS4 SU? Would it not be better to use the 1.75" HS6?
Rogue
Posted: 2005/7/7 1:04  Updated: 2005/7/7 1:04
Holy Mother of GOD!!!!!!!!!!!!!!!!!!
Pack a fire extinguisher on your maiden voyage, your gunna need one!
Good Luck
Nissan4Eva
Posted: 2005/7/16 17:47  Updated: 2005/7/16 17:47
Hi wat accel cable did u use????
Wat others Can work???? anyone...
I finished mines yesterday, it starts up fine and revs clean. But cannt drive it yet as i have no accel cable..
