Main : Mechanical : Engine 120Y/180B x-member mod
[<   Previous  2847  2848  2849  2850  2851  2852  2853  Next   >]
120Y/180B x-member modPopular
SubmitterL18_B110More Photos from L18_B110   Last Update2002/11/25 0:15    Tell a friendTell a friend
Hits7979  Comments3    0.00 (0 votes)0.00 (0 votes)
as the 180B x-member mounts in the forward set of holes in the 120Y body, it just fouls the rear of the 120Y castor rod mounting brackets. Simply need to cut a little off the back of these brackets as shown (cut one on left, standard one on right
D
Posted: 2003/5/14 1:59  Updated: 2003/5/14 1:59
From: under the Firmament LOL no twiglight effect BS
 KA 24 engine
Anyone know whats involved to stroke the L series to 2.4 with the ka24 (is that right?) on the l20b or can it be done with the l18 block too?? My friend is dreaming of a 2.4 liter engine in his newly found 120y wagon after seen Harrys post on the conversion. I shouldnt have said anything about the 2.4 L series.
L18_B110
Posted: 2003/5/14 3:10  Updated: 2003/5/14 3:10
 Re: KA 24 engine
the 2.4 stroker is a serious amount of work, and will be expensive. I think they use a Z series crank in the conversion, and crankcase needs to be machined for extra clearance for rod big ends. I'm not sure of all the internals they use.
L18's can be taken out to about 2.3 if you are very serious, but you'll have to spend alot of time to find a good block that will take this kind of oversize. They're getting pretty scarce these days. Probably need trick pistons as well in such a short block. But if you are serious about it, I can put you onto some people to source parts or build it.
Is this going to be a street car? A 2100 L20B would be a cheaper exercise, still with heaps of grunt - I'm sure he'd be happy with that for starters.
D
Posted: 2003/5/14 1:56  Updated: 2003/5/14 1:56
 Re: 120Y/180B x-member mod
Looks like a great upgrade for the one owner 120y wagon my friend found. thanks Harry.
