Main : Misc : Tech Section more A to Z series oil pump
[<   Previous  417  418  419  420  421  422  423  Next   >]
more A to Z series oil pumpPopular
Submitter1200coupeMore Photos from 1200coupe   Last Update2005/5/2 1:45    Tell a friendTell a friend
Hits4074  Comments10    0.00 (0 votes)0.00 (0 votes)
This shows the designs for the bits that need to be manufactured to turn your A series pump into a high volume pump using Z series bits.
Its the bits in the red boxes that needs to be manufactured to make it all work.
1200rallycar
Posted: 2005/10/24 12:37  Updated: 2005/10/24 12:37
 Re: more A to Z series oil pump
i'm gonna give this a shot, as i am planning on adding an oil cooler to my system
is there any oil coolers in cars typical of wreckers for engine oil type applications?
also... to check those lengths as they are hard to read on my screen anyway we have:
overall length = 108.02
smaller lengths = 34.9 and 73.12
correct????
1200rallycar
Posted: 2005/10/24 12:45  Updated: 2005/10/24 12:45
oh yeah.... material???
what should the shaft be made from?, what finish and how to get that?, and heat treatment neccesary?
blofly
Posted: 2005/10/24 13:00  Updated: 2005/10/24 13:00
hey 1200rallycar I have seen a website before they sell alot of different parts that I think you would be intersted in, one part they sold was an oil cooler kit and remote oil filter assembly. The kit just screwed on where the oil filter normally resides, and has stainless braided hoses for reliability, the whole kit was quite interesting and appeared reasonably priced .....but I can't for the life of me remember where I saw the website, one thing I do know is that it was an american web site
1200rallycar
Posted: 2005/10/24 13:15  Updated: 2005/10/24 13:15
thanks man, but im really not a fan of buying things new
i have an adaptor for the cooler already, just need the cooler itself and this shaft and i'm practically setup
COUP1200
Posted: 2005/10/25 1:26  Updated: 2005/10/25 1:26
1200rc
Try going to a pomey car wrechers. Lots of pomey cars came out standard with alloy oil coolers. I am goin to use one out of a 88 XJ40 jaguar as i already have one but i havnt trial fitted it yet. You might have to play around with the fitting though.
1200coupe
Posted: 2005/10/25 1:40  Updated: 2005/10/25 1:40
Micheal,
If you post your email I will send you the high res pic of my designs, so you can read everything. Either that or send me an email direct because I have lost your email address.
Paul.
1200rallycar
Posted: 2005/10/25 3:06  Updated: 2005/10/25 3:06
thanks guys
emails rallycar_1200@hotmail.com
would send you email but yours isn't in your profile
if you could let me know the material and finish also that would be good
1200rallycar
Posted: 2005/10/25 3:31  Updated: 2005/10/25 3:31
received cheers mate
L18_B110
Posted: 2005/10/25 6:05  Updated: 2005/10/25 6:05
just to avoid confusion, that's an L series oil pump from a 240Z. Although the Z18/Z20 etc oil pumps may well be the same given their other similarities.
Anyway, any 6cyl L series oil pump is the same as this - it doesn't have to be from a 240Z. The various model Skylines (C210 and R30) and 240Ks should be easier to find, and wreckers have a nasty habit of bumping up the price if you ask for anything from a 240Z or 260Z. btw, the L28ET has a bigger oil pump again.
1200coupe
Posted: 2005/10/25 8:03  Updated: 2005/10/25 8:03
Thanks L18_B110, I remember the confusion last time this subject came up and I went away and clarified the info. You are correct as it looks like all the L series pumps are the same (4cyl & 6 cyl) except for the L28ET.
So you can use any common L series oil pump as parts to upgrade the A series pumps and follow the details in the above pic and everything will be OK.
Final result will be a bolt on A series high volume oil pump.
