Main : Mechanical : Engine a12et in a 1000
[<   Previous  2485  2486  2487  2488  2489  2490  2491  Next   >]
a12et in a 1000
a12et in a 1000Popular
SubmitterdazzasuteMore Photos from dazzasute   Last Update2005/9/19 16:59    Tell a friendTell a friend
Hits3795  Comments4    0.00 (0 votes)0.00 (0 votes)
from ebay:
1200 engine fitted which i have turbo charged,all custom manifolds running camry injectors and throttle body,t25 turbo off a s13 silvia running 12 psi,neat 2 1/2 " turbo back system with resonator and cannon stainless muffler,datsun 1200 diff,braided turbo water lines,complete subaru rs water to air intercooler setup,running brand new EMS stinger 4424 engine management with pc cable,the ems is capable of a lot of features including anti-lag which is currently off,the rev-limit is currently set at 6500 rpm,also has a pre-pump,surge tank and high pressure pump,thermo fan
LAGWAGON
Posted: 2006/6/16 3:33  Updated: 2006/6/16 3:33
 Re: a12et in a 1000
wow, cool! is this yours? does it still run and were there any problems with it? was it a stock motor?
edit: from ebay... gotcha
dazzasute
Posted: 2006/6/16 6:36  Updated: 2006/6/16 6:36
 Re: a12et in a 1000
yeh saw it on ebay a while back so dropped in on here for ideas for people doing a series turbo...
although going by the radiator it looks like its had overheating probs...
L18_B110
Posted: 2006/6/16 7:03  Updated: 2006/6/16 7:03
 Re: a12et in a 1000
has anyone else looked into the camry throttle body?? Looks like it fits quite well, other than being back to front.
He's not saying he took a camry inlet manifold and bolted it on the A12. the ad says "all custom manifolds running camry injectors and throttle body".
the TB is just a part with about a 2" long body that contains a throttle butterfly, with a position sensor and sometimes a switch on the outside. it bolts onto the inlet manifold plenum in most cases.
dazzasute
Posted: 2005/9/19 17:01  Updated: 2005/9/19 17:01
 Re: a12et in a 1000
this is the 1000 thats on ebay right now. has anyone else looked into the camry throttle body?? Looks like it fits quite well, other than being back to front. Water to air intercooler (by the look of it) fixes that problem, and ads to the sleeper effect.
