« 1 (2) 3 4 5 ... 14 »
Re: 13 sec for $1300
From Adelaide
You make it sound easy!
Posted on: 2012/2/19 9:10
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
certainly interesting
turbo -300
turbo manifold -250
j pipe -50
meth/water injection -200?? got now clue about diy meth injection systems
tune -300
carby -well i just got an su for 50
exhaust - round 200 mark
think thats about it anything im leaving out?? thats all diy, maybe upgraded coil system with different plugs??
Posted on: 2012/2/19 9:12
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Ballarat Victoria
Ha Ha, I stuffed up on the calculation. To do a 13, you only need 115 HP atw (not 130-140) with a 700kg car. Thats a lot less power than Top Gear made with his draw thru setup.
Posted on: 2012/2/19 9:18
VIC DYNO HIRE
LJ, you could do a pre compressor WI setup for about $30 and the exhaust would be cheaper than 200 if you could do it yourself.
If you used methonal or E85 you probably wouldnt need WI.
Posted on: 2012/2/19 9:24
VIC DYNO HIRE
yea i was factoring in flange for dump pipe 40 max, new muffler 100 or so, 180 bend 30 odd and a few meters of pipe. i can't remember how much my last exhaust system cost for my ca conversion, think the shop charged 300 and i done the dump and front pipe myself but i think he bombed the price up a bit cos he owed me.
if you can do a WI system for 30$ it'd be fairly doable.
maybe it needs to be a 12 second 1200 for $1200 lol
Posted on: 2012/2/19 9:36
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
I think rules must be the following-
- must be datsun
- must be datsun 1200 motor (plenty around so theyre cheap)
- only concern is gearbox, A-series boxes arent strongest
Just a thought...
Or could allow L-series conversion for larger capacity and stronger gearbox...??
Posted on: 2012/2/19 10:44
From melbourne
How reliable/rego or is the target to do just a 13sec pass ??
Posted on: 2012/2/19 10:53
Somebody was telling me about on some forum there was a 10's for $5000 or less. That was to include buying the car and whatever engine/box package you wanted. Still yet to find it.
Posted on: 2012/2/19 11:01
From Melbourne, Australia
NOT POSSIBLE! END OF STORY
Unless you go absolutely completely bush pig with it and you have a lot of luck finding ultra cheap bits
people pretend far too often that these things are cheap t build.... they are not! too many comments along the lines of ... yeah get a CA18DET for $600 and everything else you need for $500 and you''l have a CA datto for $1100.... life is not that simple!!!!!!!!!
Posted on: 2012/2/19 11:06
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Don has 200 dollar 1000 ute, they are 615kg remove rear tailgate thats nother 10kg, Silvia disc front end, smallr battery, no bumpers, alloy radiator, A12T with 60 series four speed or toyota T40 (hint hint cheap strong box), chop roof down 4 inches for better flow, sub 600kg @ 90kwatw should do it.
Posted on: 2012/2/19 11:19
