Where to shorten diff housing
From Mandurah, Western Australia
Been looking into this and talking to a few people and I know it can be done both ways.
On a BW78 Housing would you shorten at A or B.
I am considering shortening at point A as I can put a different flange on the tube as I am not using the brakes that are on the BW 78 Diff.
Have been told that shortening at point B can be difficult as once you drill out the welds and remove the tube from the diff housing, Driving it in again and keeping it all aligned (even on a jig) is difficult.
Any one have any experience to add? I realise both methods will need to be jigged up.
Cheers
jpg  DIFF.JPG (5.58 KB)
2484_4b0146414c72b.jpg 418X202 px
Posted on: 2009/11/16 12:36
Re: Where to shorten diff housing
With most axles you can do it either way, as along as the tube doesn't neck down.
Use a jig and final weld it, it wont go out of alignment when you drive it (if the welds are done properly).
Posted on: 2009/11/17 3:47
From Nyngan, nsw Australia
i had my done at the A end with no probs yet (skyline r31), cut then sleved
Posted on: 2009/11/17 8:09
living is good,.....
From perth
cut the ends off
shorten tube
weld ends back on
all done in a jig
i considered putting 9" ends on my hilux diff using 9" axles and have a massive choice of bolt on brakes
should i again mention talk to phil?:)
dazza
Posted on: 2009/11/17 11:19
From Geelong, Vic
if you shorten it at point A you cant just cut the tube down and weld a different flange on, as the tube has the recess in it for the bearing
you need to cut the end say 73-100mm of the diff off then cut out what you dont need from the tube then weld the end on
when doing it at point B i dont see how it could go out of straight...it takes about 20ton of pressure to get the tube back in again and its in there a good 3 inchs or so...aint nothing going to move it even without welds on it
ive done both ways on BW78s (dad just happened to have a hydraulic ram that fitted inside the axle tube) i did 2 diffs by pressing the tube out and pressing it back in
but just cutting the ends off is quicker and easier to line the end flanges up again
Posted on: 2009/11/17 11:24
From perth
you would be ammazed how much things move around when you use a 20T press on them. even big stuff
if it galls going in it will cock to one side
Posted on: 2009/11/22 4:03
I will also go with the A end option, agree with your statment.
Posted on: 2010/4/26 5:45
check out 000-010 term.
From Ballarat Victoria
I havnt shortened a diff before but i know they are easy enough to straighten and bend to where you want later.
The diff housings ive done for racing have to be aligned and camber added and they bend/straighten easily.
You would start with everything as square as possable to start with tho.
I can help you with a diff bender design if you run in to sraightness issues.
Posted on: 2010/4/26 6:21
VIC DYNO HIRE
From Perth
Go see Phil
But pick up my housing on the way
I need one done too
Posted on: 2010/4/26 9:41
From mandurah
add me to that list haha
Posted on: 2010/4/26 10:17
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
