converting the A series to full ECU controlled fuel n spark
From Darwin NT
hey guys this is going to be sort of a build thread as i endeavour on my way to building my a15 to be controlled fully by an ECU, just for those who wish to remain with the mighty A series, ive noticed there is not much solid info on this sort of a build.
so slowly but surely ill keep adding to this thread, anyone who has any experience or knowledge by all means please add to this thread.
Posted on: 2011/2/25 6:23
current project 4x4 patrol...
Re: converting the A series to full ECU controlled fuel n spark
Just use the factory parts.
Posted on: 2011/2/25 6:29
From Darwin NT
hmm im thinking more along the lines of twin 45mm weber style thottle bodies, =D
Posted on: 2011/2/25 6:37
Yes, these are more popular than the factory setup. About $2500 will do it, if you use a cheap ECU.
Posted on: 2011/2/25 6:42
Quite a regular
From Bellville, RSA
I'm also busy planning to converting the A14 to EFI.
I have the GX head on, so decided to run to 43mm Toyota throttles off the GX manifold.
Hopefully in will run as good as the twin Hitachi's.
Posted on: 2011/2/25 6:44
Datsun 1200 Sedan
From Darwin NT
ohk im planning on using an fj20 dizzy, for the crank angle sensor
i have one back home (i assume it an fj20 item as it come with a heap of fj20 parts) and it pretty much bolts in with very little modification so it should work. im busy trying to find all the info i can.
Posted on: 2011/2/25 6:59
From Melbourne, Australia
how bout with two turbos....
Posted on: 2011/2/25 7:09
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
now that is beautiful. A Twin Turbo A-series.
Posted on: 2011/2/25 7:15
From Perth
I heard rotary dizzys can be used for cam angle sensing too
Theres some A series pics around here with crank angle sensor driven off the front pulley
Posted on: 2011/2/25 11:09
From Ringwood, Melbourne, AUS
What about a std Nissan optical cam angle sensor driven off the front of the cam like the mechanical tachs?
Machine the front timing cover and mount it to that??
Posted on: 2011/2/25 11:49
Deano
