A10 versus A12 Dyno Sheet comparo
Factory B10 dyno chart with factory A12 lines superimposed
It seems the A12 betters it at all RPMs. What advantage does the little A10 have?
Posted on: 2012/5/14 7:32
Re: A10 versus A12 Dyno Sheet comparo
From Malaysia
what about engine weight? a12 vs a10...
Posted on: 2012/5/14 7:44
D will know the answer to that -- calling D!
Posted on: 2012/5/14 7:52
The A10 works great for going slow? haha. I would love to see a heavily worked a10,would be pretty awesome to see!
Posted on: 2012/5/14 9:53
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From south coast nsw
economy
Posted on: 2012/5/14 10:05
From vic
is this rwhp or flywheel horsepower?
Posted on: 2012/5/14 10:31
From Wanneroo, Western Australia
Greendog's right, economy is the only advantage. But really it's all about one thing: pedigree! Kinda like having a Sloper and replacing the flathead with a Boss 302... Sure the Boss will go harder, but it's just not quite "correct"!
Posted on: 2012/5/14 11:22
You guys answered it all almost!
The kb10 is at 66hp its only 2hp off the a12 as a single carb setup.
An A12gx vs A10gx might be interesting both with oval port heads! :)
Although 10kg doesnt sound like much when you compare power to weight
of the single carb A10 from a KB10 vs the A12 then the A10 might win.
I personally prefer the A12 w/ 3.9 in my 1000 by along shot though :)
However my coupe with the A10 is a different experience than the VB10
its feels more sporty as you have to revv it more so requires a diff
driving style yet economy is incredible probably another 20% better.
A12 with 76mm bores cant go wrong though!
Id be more interested in comparing the most rare of all the A series egines
The A13 long and short stroke versions if they exist from past threads
eg
1289cc 77mm stroke and 73mm bores
vs
1270cc 70mm stroke and 76mm bores
Posted on: 2012/5/14 13:14
Factory HP is always flywheel HP.
Posted on: 2012/5/14 17:19
From Malaysia
eg
vs
you've mentioned 76mm bored A12. even my 75mm bored A12A in stock condition have considerably more torque than stock A12. put a H89 and the engine is happier to rev.
Posted on: 2012/5/14 18:13
