Wheel Weights
From Central Vic
I would like to propose a new section for the site
Wheel weight greatly effects unsprung weight and this effects the handling so the lighter the better.
I have recently been trying to find the weights of wheels and have started weighing what rims I have.
I will post my wheels and weights on the weekend but hope others can do the same as I was quite shocked at the difference to be found.
So weights without tyres would be great
Posted on: 2008/7/2 23:02
to buy or not to buy???? OK
This is the reason I have five coupes
Re: Wheel Weights
From Brisvegas, oz
sounds good i would love to hear about the weights
Posted on: 2008/7/3 2:40
www.camerasplus.com.au
Re: Wheel Weights
From SE Melbourne
Try this
http://www.wheelweights.net/
- but if you would like to start a section about wheel weights - do it in the Wiki.
Posted on: 2008/7/3 3:37
Mildman, Datsunless
Re: Wheel Weights
I like the stick-on wheel weights. You can put them on the inside of the alloy wheels.
Here is the new section at Datsun1200.com, please fill it up with good facts about wheel weights: Wheel Weights
Posted on: 2008/7/3 3:42
Re: Wheel Weights
From Townsville, Qld
yes they are good but they tend to fall off the wheel if the surface isn't really clean. I have the clip on type on the inside of my race wheels, they balanced out great.
As for the weight of wheels? well our cars really benifit from using rims which weigh under 10kg cos when you add the tyres that's almost double in most cases
Posted on: 2008/7/3 10:34
Re: Wheel Weights
[stick-on weights] tend to fall off the wheel if the surface isn't really clean.
Speaking of which, here's what greeted me this morning:
Posted on: 2008/7/5 2:54
Re: Wheel Weights
From Canberra
Dont get 15x8 steel wheels, 25kg each with tyres
Posted on: 2008/7/5 3:55
Re: Wheel Weights
From Victoria
thats heavy enough!!
Posted on: 2008/7/5 5:47
Re: Wheel Weights
Sorry DD but I can't help but laugh at that when i read it
Posted on: 2008/7/5 6:15
Re: Wheel Weights
well yes I had a wry grin when I saw it. The problem is the wheel is now unbalanced. If I can see where it was fitted, "Shoe Goo" (or duct tape) should stick it back on. You reckon?
Posted on: 2008/7/5 6:19
