« 1 (2) 3 »
Re: Temp. reaches 3/4 only driving 10 min. !!!
From Las Vegas USA
Just a word on the thermostat; I 'm in Las vegas and some of our race & trackday weekends will see temps in the 105-112 F range, I run a thermostat and with the 3 core GX radiator have no issue with cooling. Now back when we had the 2 core standard rad (recored) once the car went over 4000 RPM it would run hot, to the point of me running the heater to keep the car in the 7/8ths range. Put the proper thermostat in, the car will be better all around.
Tom
Posted on: 2009/8/6 2:23
From Delaware, USA
I will do that as soon I get my radiator back. What thermostat do you mates recomend?
Posted on: 2009/8/6 13:18
From hastings,vic
u havent increased compresion??
or have u.
to mutch timing??
diffrent head?
Posted on: 2009/8/6 13:31
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From Delaware, USA
I didn't touch the timing. A different head ( A13 )now. The compression should be the same or less. My A12 head was worked a little for more compression. But I'm going to change the core of the radiator from a 2 to a 3 core and see from there what happens.
Posted on: 2009/8/6 21:22
Why don't you double-check the actual temperature before doing that? The temp sender may just read higher, but it's not actually running any hotter. It is a possibility that happened to another club member last month.
"if it ain't broke, don't fix it"
Posted on: 2009/8/7 2:32
From Delaware, USA
The temp is hot, you couldn't even open the cap until it was cooled down. It was reading right. But the 3 core is still needed for when I drop my other engine. I just want to have this engine running good before I yank it out of my car. Question DD, I have an electric fan and I was wondering if it works better behind the radiator or front the radiator ?
Posted on: 2009/8/7 13:19
From south coast nsw
u need the cooler air the hit as much of the front of the radiator as possible,putting the fan on the front would reduce the radiator performance.
Posted on: 2009/8/7 16:10
From Delaware, USA
Then inside it will be. Thanks GreenDog.
Posted on: 2009/8/7 23:18
From sydney australia
The best thermostat to use in the warmer months is the stock one. There are two other thermostats, the tropical one & the artic one as they were labelled by a friend. the tropical one opens earlier & is best for race cars, while the artic one is good for a cold winter, as it opens later. I think there's a 5 degree celsius difference between the three. I agree with Dodgeman, I think that the problem will be a clogged radiator, as the 'rubbish' from the block will have come out & clogged the core. Happened with the B310 coupe with an L18 I own, there was so much junk in there I've had the radiator cleaned twice & I'm still catching rubbish in the filter. Tefba here in Australia sell a cleanable filter, they have a website if you're interested, but there's no room in the top radiator hose for their one. Natrad here in Australia can supply the filter D'man mentioned, the first time I cleaned mine I found swarth in it from the engine. Hopefully getting the triple core will cure the problem for you.
Posted on: 2009/8/8 0:11
From Albuquerque NM, USA
Nissan has a t-stat kit that has gaskets in it
Part # 21200-P7990...fits most datto engines from the '70s and '80s including the A
probably around 20 to 25 USD if it is still available though the dealer, been about a year since I got one
Good luck with it
Posted on: 2009/8/8 0:52
« 1 (2) 3 »
