Posted on: 2013/5/29 16:12
Edited by unfamilia on 2020/3/29 13:38:11
Re: Satnza issue continued
Change the thermostat. Or for testing, remove the thermostat and see if the symptoms change.
Posted on: 2013/5/29 16:29
From Sydney
My money is on a radiator that needs a service. At least take it out and give it a flush with a hose. The oem temp sensor/ needs to be looked at also, by the description you gave.
Posted on: 2013/5/30 0:45
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Posted on: 2013/5/30 1:19
Edited by unfamilia on 2020/3/29 13:38:32
From Sydney
Water pump could be dodgy as well then.....
Posted on: 2013/5/30 1:43
1970 KB10 Coupe
S13 caliper b...
From Ballarat Victoria
Sounds like it wasn't bled properly. If there is a big air pocket around the thermostat, it wont open and water won't circulate.
If you change the thermostat, ensure the little bleed hole is at the top. or even drill it out to about 4mm.
Posted on: 2013/5/30 1:44
VIC DYNO HIRE
From Adelaide
Pretty easy to test the thermostat, stick it in a pot of cold water on the stove and turn it on. If you've got a thermometer that goes up over 100 deg C you can see when it actually opens.
Simon's suggestion also sounds plausible.
Posted on: 2013/5/30 3:43
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Posted on: 2013/5/30 4:08
Edited by unfamilia on 2020/3/29 13:38:49
From MOOROODUC. Victoria
I second the drilling out the hole
Posted on: 2013/5/30 7:35
From Perth WA AUS
Yeah ream that hole!
Posted on: 2013/5/31 10:11
Datsun 1200 2Dr sedan.
