radiators in race cars
From Taupo New Zealand
what radiators do you racers use?
I was thinking a 310 radiator with a new triple core maybe?
I had my 1600 radiator recored with a new triple core, it's great and hasn't even looked like overheating since.
Could do the same for the 1200, but was thinking aluminium would be better, could get away with a smaller one due to the better heat transfer properties?
Posted on: 2004/9/14 7:25
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Re: radiators in race cars
From sydney
this is mine should work well
Posted on: 2004/9/14 7:44
From Newscastle, Australia
I use a Gemini TF one (4 inches wider than stock 1200 and you can run standard hoses)...its not the water temp which is a prob on the A series...its oil temp...so make sure you run an oil cooler..
Posted on: 2004/9/14 7:52
Dont die wondering.....
cheers converted, oil cooler wouldn't be a bad idea, but, one thing at a time!
I wish I could do everything at once sometimes though!!!
what year is a tf gemini? they're not very common over here.
Posted on: 2004/9/14 8:05
1970 1200 coupe A15
1978 B310 SR16VE
Quite a regular
In my y i run a series 3 bluebird radiator (ca20 motor) and two 10 inch thermos. On a 42 degree day it doesn't go over 86 degrees. I also run a 400x200x40 oil cooler.
Posted on: 2004/9/14 9:09
120y 2dr sedan, Z18t
From Perth
6 cyl Torana LJ 3 core
Posted on: 2004/9/14 11:08
From Brisbane
Posted on: 2004/9/14 13:53
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Thats all OK for street cars guys but you must run an oil cooler for a race car...otherwise the oil will boil. This is the archilles heal of the A series.
$200 for a complete kit is all it will cost
Posted on: 2004/9/15 0:10
From Millgrove Vic OZ
You must run an oil cooler for a race car...otherwise the oil will boil. This is the archilles heal of the A series
I'snt that why Tomei made their alloy 6 litre capacity bat wing sumps tomei alloy sump
Posted on: 2004/9/15 0:41
Cheers Feral
Hey feral, do you sell these or similar?
Posted on: 2004/9/15 1:48
