removing battery tray
From young
Hey all i need some help/advice on how to remove the battery tray in my ute any info is much appreciated THANX Appsy1
Posted on: 2007/8/11 13:22
1200ute jelly bean mags
twin 40mm dellortos
Re: removing battery tray
cut it out.
Posted on: 2007/8/11 13:33
From Adelaide
or drill out the spot welds
Posted on: 2007/8/11 13:40
From Brisbane, Australia
Use a spot weld drill:
1. Centre Punch and Spotweld Drill
2. Drill through the first layer
3. Remove first Layer
The spot weld drill is basically a flat cutter with a tiny centre drill.
It can be hard to access all of the spotwelds for the battery tray. You may need a combination of drilling and cutting.
Posted on: 2007/8/11 13:47
Quite a regular
Let us know how you go with this one, I was going to tackle it this weekend but I'll wait to hear how your go.
Posted on: 2007/8/11 13:49
From sydney
I used a cold chisel and a hammer but did leave one small split in the steel.
Posted on: 2007/8/11 14:22
From Geelong, Vic
just cut the thing off where you can then grind off whats left
Posted on: 2007/8/11 22:36
Quite a regular
Yeah I was having a look at it this morning and its an odd shaped bastard! Removing it properly with a spot weld tool would take ages.
Posted on: 2007/8/12 8:38
From Flinders View, QLD
Just do what PIGDOG says, it would be quick and easy. Thats what I will do with mine.
Posted on: 2007/8/12 9:53
Just trying to put the bloody puzzel back together
From Melbourne, Australia
done it a few times, i just cut off the tray and leave the flat parts still spot welded on
that spot weld drill bit would be much neater!
but motor would have to be out to get to one area of them
Posted on: 2007/8/12 13:52
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
