Re: A13 RACE HEAD FLOW FIGURES
Roller rockers are for reducing friction and wear, important in a race engine for sure. But non-roller rocker arms can have a higher ratio as well (which does increase lift and duration).
Roller lifters on the other hand enable a different cam profile that can open faster than is possible with a flat tappet. They reduce friction as well.
The ford factory roller V8s have a different machined block ... but camshaft companies sell roller lifters for every kind of V8.
Posted on: 2003/4/18 6:13
From Fort Worth, Texas, USA
Hate to rain on the parade, but I don't see how roller lifters could be made for the A-series. The lifters are very small, unlike a V8's lifters. Also, there would need to be some provision to keep them from rotating so the roller is oriented correctly.
Hey, I just had a thoght. If they could make a ball-end lifter of some sort, it might not need to be as big and wouldn't care how it was oriented to the cam.
(edit)
No, just thought about it and the surface that rides on the cam has to be pretty big or it won't ride up on an agressive lift cam.
Posted on: 2003/4/18 16:53
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
From Millgrove Vic OZ
Nismo rockers have a 1.5 : 1 ratio. Stock A rockers have a ratio of 1.44 : 1.
As dimlight said, the A lifter blocks are too small for a roller setup to be effective easily.
The amount of lift available with the A series valve stem length/spring combination before coil bind (typically 0.480" for most double spring sets) is also a major performance limiting factor. This is why the A needs a long duration camshaft.
Posted on: 2003/4/18 23:23
The yella terra rockers give a 1.65 lift ratio vs 1.44 stock. Damn fine items.
Posted on: 2003/4/18 23:24
From Newscastle, Australia
Andrew, Teretonga and I were over at John Taylors, and he's claimimng 200hp at the fly for that A15/inj setup....normally aspirated!!
It also uses roller rockers, but I dont think he had a roller cam in it.
Posted on: 2003/4/20 10:22
From Invercargill, New Zealand
And while we were there he flowed the CWR Autokhana Sunny A12 head. It returned a peak flow of 27 hp - apparently some of the valves have fallen off...
Posted on: 2003/4/20 10:32
From Christchurch New Zealand
how many ml's of liquid do the ports holed
ex and in
Posted on: 2003/4/24 7:23
"If your not living on the edge your taking up too much space" Rod Millen
From Sydney
Yella Terra also do a 1.5:1 unit as well
Posted on: 2003/4/24 7:55
I will check for you after the revalve job. I am putting in nitrided 214N stainless one piece for more durability over the titanium valves. I will not run it up as high as it was running before probably keeep it to 9000 -9500 rpm with the new valves due to increased weight.
We are also doing different transitions from stem to head on the new valves as well to try and crib a bit more flow. Chambers are also being recut with to improve seat to chamber radius.
Posted on: 2003/4/25 11:55
« 1 2 (3)
