question for the turbos
From Perth WA
May seem a stupid question, I havent had a turbo before.
Not about my datsun, it hasnt been started in months
How do you increase the boost on a turbo,
just a couple of psi over stock
Posted on: 2008/3/14 4:48
Re: question for the turbos
You could shorten your wastegate actuator rod on an integral gate,
Or you could use bleed valve or increase the sternal gates spring pressure
Posted on: 2008/3/14 4:59
Jesus drove a datsun
`67 B10 Turbo white
`69 VB10 red
`71 S30 (240z) orange 432R style
`78 P330 (280c) president matte black
`76 p330 (260c) wagon silver
`96 Toyota Hiace 2.8 diesel LWB
From Perth WA
so theres no simple adjustment then?
Posted on: 2008/3/14 5:21
From Newcastle
crimp the hose that runs to the wastegate or take it off and il run max boost done this on me exa used to run 8 pound everyday then when i took the hose off the gt28 would spit out round 17pound
Posted on: 2008/3/14 5:50
From Perth WA
I was after a small increase to start off!
Posted on: 2008/3/14 5:56
From Christchurch NZ
Get an airtight vessel, and run a hose from the wastegate actuator line to it. The turbo will have to fill the vessel with pressure before the wastegate can open. This will cause a nice boost increase mid range, but the boost will flatten off in the higher revs.
Posted on: 2008/3/14 6:48
Forced Induction!
From Canberra
or you could spend $40 and get a turbotech boost controller off ebay....
Posted on: 2008/3/14 6:58
The method I described only increases boost lower in the rev range, when there is plenty of spare injector cycle available. Reduces the risk of lean out from injectors maxing out.
Posted on: 2008/3/14 7:37
Forced Induction!
From Perth WA
think i will go with tyries suggestion, more control I dont want to blow it up. thanks for other ideas.
Posted on: 2008/3/14 7:55
From Canberra
I have one of these, was only used for a tune (1hour) then put back in the box. Is missing the silicone hose. Yours for $20 posted if you want it.
http://cgi.ebay.com.au/GFB-atomic-boost-controller_W0QQitemZ270219376005QQihZ017QQcategoryZ130654QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Posted on: 2008/3/14 8:11
