a14 - Build and Sell
hey guys,
i am mid way thru the conversion (ca18det in1200 ute) and my 1200 when i brought came with a a14 in it. instead of sitting it in the corner im going to build it up with some mild work (mainly head, unless i can find a big cam and stroker kit ;) and sell it. with trans. - or even trade
the build will not take me long.
to start:
head stripped down, rockers off. the rocker shaft off (to be balanced and made sure no bends or anything) then will have the valves out and the head sent off for some work and dipped and cleaned in a special acid. should be good. block will be torn down saturday, dipped in acid bathed fully cleand bores tidyed up then build time.
Ben.
Posted on: 2008/7/3 14:04
Re: a14 - Build and Sell
From Sydney
ca's suck balls use the a series....
Posted on: 2008/7/3 14:39
From SE Melbourne
Nah you got it wrong SR's suck balls.....
Posted on: 2008/7/3 14:52
Mildman, Datsunless
From South Brisbane, QLD
They both suck balls, A series rule....
Posted on: 2008/7/3 23:30
Skyline Productions
1985 Datsun 1200 ute, trailer trash.
1994 Suzuki Sierra, weekend warrior.
From Darwin NT
yup keep the a14 throw the ca and turbo the a14 you can get it to run highs 11's if you build it right talk to finn on this site his 1200 coupe ran a 11.92 pass with a bad launch and head gasket problems and it would probably cost you the same amount as putting the ca into the car....
Posted on: 2008/7/4 0:05
current project 4x4 patrol...
From ACT Aus
and the a series would handle so much better.
Posted on: 2008/7/4 6:49
From perth airport
sr all the way
Posted on: 2008/7/4 7:11
perth airport parking
Datsun 1200 ute A14
From Christchurch NZ
A series FTW!!!!!!!!!!!!
Posted on: 2008/7/4 8:03
Forced Induction!
From Mudgee, NSW
perthute wrote:
sr all the way
FAAAARK YEAH............. Screw the A series, get with the times people.....
Posted on: 2008/7/4 8:16
200b - SR20det project....
A looooooong term project
From Sydney
if u like the sr and ca so much then leave our datsuns alone and go buy urself a crappy rice buring 180 or 200 geeeezz sorry bout the thread highjack
edit: dont forget ur fully sick noise making things and hecktic 17 chomies lol
Posted on: 2008/7/4 9:03
