Full time Turbo
From Sri Lanka
Hi Guys
Just wanted to know whether you get facility in a turbo charger or super charger to make it active whenever you want and deactivate whenever you don't need it ?
Thanks
Regards
Sumith
Posted on: 2009/6/19 5:32
Re: Full time Turbo
From northern 'burbs adelaide
you can with a supercharger but i dont see the point ... if you build a motor for boost you will need boost all the time
Posted on: 2009/6/19 7:16
Re: Full time Turbo
From perth airport
boost controler and be in the cab with you so boost on or boost off ( well down any way )
or take the sir clip off the boost aucutor and thats no boost :) 2mins to do it
but why ?
Posted on: 2009/6/19 8:07
perth airport parking
Datsun 1200 ute A14
Re: Full time Turbo
From Sri Lanka
Hi perthute
Your answer is not much clear for me , i am not having much knowledge about turbo,what i wanted to ask is can you on and off turbo just simply by a control switch while you are driving ?
thanks
regards
sumith
Posted on: 2009/6/19 8:28
Re: Full time Turbo
with what perth ute says you can set up a "boost controller" which adjusts the ?wastegate? (please correct if wrong) to open up at different boost pressures
Posted on: 2009/6/19 8:31
Re: Full time Turbo
From Sri Lanka
Hi aidaniel
OK, Now it is clear , is it possible to stop the boost completely ? or you get some controlled levels of boost to select ?
thanks
regards
sumith
Posted on: 2009/6/19 8:41
Re: Full time Turbo
From perth airport
the waste gate has a lowest setting eg factory (say 6psi )
using a boost controller your tricking the factory waste gate into making more boost but imo you cant go lower unless you unhook the rod that goes to the waste gate
click there so see the rod im talking about
i guess your not aloud to have a turbo with the new laws for p platers ? and your beeing clever buy trying to turn off the turbo ?
Posted on: 2009/6/19 8:59
Datsun 1200 ute A14
Re: Full time Turbo
nah he's from sri lanka i think
Posted on: 2009/6/19 11:43
Re: Full time Turbo
From Christchurch NZ
A clutched supercharger would give you on off capability. or maybe have a throttle body in your bost line with a central locking actuator might work.
Posted on: 2009/6/19 12:19
Forced Induction!
Re: Full time Turbo
Sumith what is the car in your avatar?
by the way a supercharger is what you need.
Posted on: 2009/6/19 13:15
