diff noise???
From vic
hi i finnaly got my 120y registered and took it on the highway i noticed i whine at high speeds (100km) when you let go of the accelerator it dissapears then press it and makes whine again!
could this be bearings on axle or diff centre? i will check oil level on saturday!
also its a auto!
thanks!
Posted on: 2011/5/1 10:32
Re: diff noise???
Not too shy to talk
From new zealand
mine dose the same. think its the pinion bearings
Posted on: 2011/5/1 11:47
Re: diff noise???
From Bendigo, Victoria
My ute been like that for years, just turn the radio up a bit louder every 6 months. Dulls the noise a bit.
Posted on: 2011/5/1 11:50
Re: diff noise???
From Nations Capital, Australia
Ivan that's hilarious!
Posted on: 2011/5/1 11:54
Re: diff noise???
From Mandurah, Western Australia
Un-likely to be bearings if the noise goes away when you back off.
If its a Borg Warner diff I would lean towards the crown and pinion being worn. Or the pre-load on the crown and pinion is way off.
Posted on: 2011/5/1 11:55
Re: diff noise???
Not really that funny, sounds like a jumbo jet at 100k's
Re: diff noise???
I have a simular whine, under hard acceleration. ZBut it dissappears when my wife gets out of the car.
Yours will be either pinion bearings, crownwheel/pinion whine or low oil.
Posted on: 2011/5/1 12:11
Re: diff noise???
From Albury
Probably worn the hardening off the crown wheel and pinion.I have a couple the same.There is supposed to be an additive to put in the oil to help with this.
Cheers
Bob
Posted on: 2011/5/1 12:12
Re: diff noise???
mine does it too, usually when i drive away from revhads house, and his fits of laughter.
nah, mines a h150, and whines at 100kmh and up. they all seem to do it eventually. im with ivan, and save up for a h165 conversion eventually.
Posted on: 2011/5/1 12:44
Re: diff noise???
From Perth WA AUS
Hahaha, Rev my diff whine dissapears when the wife is in the car, I think my wife whines more than my noisey diff!
Posted on: 2011/5/1 12:55
Datsun 1200 2Dr sedan.
