Re: Upgrade Datsun 1200 Front DIsc Brake
Do the 280zx swap man, super easy. Super effective. Click on the link above for more deets.
Search the threads for the Oregon USA man who will sell you the bracket and bolts.
All you will need are the rotors (can be bought new) and some Sunny or pulsar calipers from a wreckers/dismantler. Brake hoses can also be bought new. Get wheel studs from Nissan Maxima/ Ultima.
Not sure if Europe had the same model availability as JDM or Oz and NZ, but you could always buy from those markets.
Posted on: 2016/4/22 10:55
From Lisbon
i Saw, i need to identify the reference of this brake caliper
http://i88.photobucket.com/albums/k16 ... olid%20rotor/100_4314.jpg
and this rotor 250mm????
http://i88.photobucket.com/albums/k16 ... olid%20rotor/100_4313.jpg
and i will order the the brackets and studs from forum memmber
and fit on my 13*6 minilite whells
Many thanks
Luis
Posted on: 2016/4/22 20:35
Quite a regular
From Aberdeen, UK
ddgonzal is right the big callipers are r33 skyline, I could rip the ones off my s13 and see if they fit on the datto but I have 14s so I wont be able to tell you if they fit 13s or not
Posted on: 2016/4/22 20:38
From Lisbon
thanks,
its a conversion made by a member who makes brackets and sells to members. I need to identify the reference from this caliper and reference from rotor, to search the dimensions and check them with my whells, and buy the caliper and rotor
This is the caliper that i have to buy?
http://datsun1200.com/modules/mediawi ... tle=Template:B12_Calipers
http://www.nissanpartsdeal.com/parts/ ... e-frt-rh~41001-05a90.html
i cant find any identification from rotor?
I want upgrade brakes, im focus on it... i dont give up, but i need your knowledge and experience...
Luis
Posted on: 2016/4/22 20:46
Edited by Luigi on 2016/4/22 22:03:31
Edited by Luigi on 2016/4/22 22:24:10
Edited by Luigi on 2016/4/22 22:25:00
Edited by Luigi on 2016/4/22 22:32:03
Edited by Luigi on 2016/4/22 22:34:59
Edited by Luigi on 2016/4/22 22:37:40
Edited by Luigi on 2016/4/22 22:39:13
Edited by Luigi on 2016/4/22 22:39:59
If you use those brakes, the wheels will be pushed out. That's the Mike Klotz 280ZX rotor-over-hub swap. For exact caliper and rotor part numbers, see our Datsun 1200 tech article: 280ZX Brake Upgrade
These two swaps won't push the wheels out:
* B310 245mm rotors. See See Big Disc Upgrade
* S13 250mm rotors. See S13 Brakes
The only one of all these to use Vented Rotors is the S13 Brakes
280ZX and S13 won't fit over many 13" wheels
B310 fits over virtually all 13" wheels
Posted on: 2016/4/22 23:51
Is there anyone selling the B310 swap kit? Ready to go with the two parts required:
1. Needs simple machining and a spacer ring to change the large 73mm hub reg to 70 mm
2. Need a caliper adapter to move the caliper out 16 mm
Posted on: 2016/4/23 0:00
Not that I've heard of. However any machine shop can fabricate the ring, which is 3 mm wide and 70mm I.D. -- something like that. Take both the new disc and the 1200 disc hub to the machinist for measuring
The caliper adapter is likewise simple to fabricate. It's just a plate with four holes, and it depends on which caliper you use. I'd recommend the B310 caliper which uses larger brake pads, although zigmondo used PBR calipers
Spacer ring is shown in this photo, also shows caliper adapter bracket for 120Y PBR calipers
Posted on: 2016/4/23 0:26
From Lisbon
Many for your help.
I will study it, and take some measures
Posted on: 2016/4/23 19:55
« 1 (2)
