Good Bits For Sale
From Newscastle, Australia
Foam filled fuel cell near new $150
14 x 7 bathurst globes $300 no tyres (with 195/60/R14 Yoko Advan Racing Tyres 2 @ 60% and 2 @ 95% tread $850 with wheels)
John Taylor hand made rear anti-tramp springs $350 (includes all nolathane bushes)
Koni adjustable shocks suit coupe / ute rear near new $250
Ute rear 4.875 locker near new semi metallic brake linings and wheel cylinders 75mm high tensile studs $300
Brake bias valve $85
Brake master cylinder (new) and lancer booster (rebuilt) $200
Autometer/ Autogauge 6" monster tach with adjustable shift light $150
VDO Oil press Oil temp gauges with senders $100
Autogauge Water temp and sender $50
Front adjustable height struts with built in 2 degrees camber with John Taylor modified shortened inserts 300lb king springs stanza lower control arms modified castor rods and nolathane bushes and noltec adjustable camber, castor strut tops. (worth $450) 200B GX brakes 75mm high tensile studs with rebuilt alloy girlock calipers and new semi metallic racing pads. $900 the pair ready to bolt in.
Steve Draheim flare kit some superficial repairs needed to 3 flares front and rear spoiler excellent (worth $600 and very hard to get) $450.
Steering column with all new steering components from tie rod to tie rod complete $100.****SOLD****
1200 cross member $50
Brass button clutch to suit L series flywheel and 63A gearbox $100
Rebuilt Twin Dellortos and A series manifold jetted for engine (includes linkages) $450
Reasonably negotiable...
PM me for more details..
Posted on: 2005/7/11 8:18
Dont die wondering.....
Re: Good Bits For Sale
From Melbourne, Australia
how mutch 2 send 2 me the flares front and rear 2 Melbourne vic
Posted on: 2005/7/11 8:29
When the going gets tough the Datsun keeps going😋
From Taupo New Zealand
pm sent
Posted on: 2005/7/11 8:35
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Stray-ya
What size dellorto's?
Round or oval port manifold?
Posted on: 2005/7/11 9:00
Sorry, the manifold is oval port and Dellortos are 40mm DCOE
Posted on: 2005/7/11 12:07
From Sydney, Australia
When Can I pick up the steering bits?
I'll be around on the weekend, will then be ok? Or do you want me to pick them up sooner?
Cheers,
Chris
Posted on: 2005/7/11 13:09
From Brisbane, Australia
what size is the fuel cell, and where did you mount it?
Posted on: 2005/7/11 14:14
Harry, the fuel cell is an RCA type / 44litres and I sit it on the boot floor...Its is made of plastic and fully sealed. It can be easily mounted under the boot floor with just the filler sticking through the boot floor. The reason for sitting it on the boot floor was ease of install and also I only run 10-15litres at a time, not enough to upset weight distribution too much....although ideal would be to have the weight lower of course...
Posted on: 2005/7/11 19:26
Couple more things rear screen 1200 coupe $80 ***SOLD***
Rear quarter (right) $50
Rear quarter (left) slight dent $20
bootlid coupe $40
Wiper motor including all linkages and wiper arms and blades $20
tail lights coupe $30 pair
Dash good condition $30
Cobra FIA seat Monaco near new over 4 years on FIA certification left $300
race seat suit 1200 mounts recaro older style very comfy and supportive $90
Front Bumper $50 has tow loop in it
Rear Bumber $25 has tow loop in it
front grille $20
Posted on: 2005/7/12 5:50
From NSW
PM sent regarding rear screen $80.
Cheers
Dan
Posted on: 2005/7/12 8:33
