Re: how to lower front leafs
Not too shy to talk
From Christchurch New Zealand
whatever king
Posted on: 2005/9/15 12:56
Whatever Joker
Posted on: 2005/9/15 13:01
lowering blocks eh now that is a stupid idea iv revesed leafs before and have experinced them for a number of years no probs about 2 inch drop and firmer ride i dunno whether its ilegal (maybe if you drive like a twat) it costs nothing and you can do it and undo it in an afternoon.
Posted on: 2005/9/15 13:11
From Perth
Posted on: 2005/9/15 13:36
From Tracy ,Ca
anyone click on the links at bottom of phukdotaspok reply
Posted on: 2005/9/16 3:35
Quite a regular
So should I take it in to Pedders and get them to tell me whether I can lower the front?
Posted on: 2005/9/16 3:37
From gold coast QLD.
Sooo simple depending where you live
But do go to pedders if you want to get
really pi__ed off.
Posted on: 2005/9/16 7:08
From Perth WA
u can be forgiven for thinking lowering blocks and longer u bolts are the way to go, that does work where u have leaf springs onto a thick diff axle and the axle sits atop the leafs.
however the front of a 1000 is not like that, the way to do it is to cut down the rubber blocks that sit between the crossmember and the leafs. there is not a lot of travel as it is in that front end and this being done without uprating the spring rate will probly cause a lot of bottoming out and bouncing/crashing through potholes etc.
u could instead leave it original...
Posted on: 2005/9/16 7:28
Quite a regular
i live in vic and the front needs to go down due to the way the front end is very wondering at high speeds. it just sits up to high, maybe a front spoiler
Posted on: 2005/9/16 9:12
if you're keen to go to a pedders dealership try the one in carlisle st, st kilda. karl (if he still owns it??) helped me heaps in getting my 1200 sorted 1st time round, and is a big fan of dattos.
as for lowering it, its pretty much the same deal as your rear leaf springs - measure from the bottom of wheel rim, not the tyre, up to the guard lip and work out how far you'd like it to come down. do this for both sides, write down your measurements, pull out the spring (pretty easy job in a thou) mark drivers/passengers sides and take it into pedders to have them reset it to how far you'd like it to be lowered.
don't go cutting rubbers or trying to fit u-bolts or other dumb stuff.
good luck
Posted on: 2005/9/16 9:49
« 1 (2) 3 »
