Re: questions about camber and castor
From Newscastle, Australia
Very nice work Morgan. I might get you to make me up a set.
Posted on: 2006/2/10 0:48
Dont die wondering.....
From Brisbane
Nice job Morgan, I see your getting the struts ready for the adjustable spring platforms.
Posted on: 2006/2/10 6:38
From Perth
Speaking of new struts..... I just got mine finished and installed.
Before and after pics at My Website
Posted on: 2006/2/10 11:40
you dont muck around do ya Mark.
Mate you should have your own class:-
V8 Supersunnys
Posted on: 2006/2/10 13:48
From Perth
If your going to do something - you may as well do it right
Posted on: 2006/2/10 23:07
From sydney australia
are these commercially available mark,or are you going to sell them through your business.
lots of camber with that offset,& all at the top so the wheel track stays close to original.
Posted on: 2006/2/11 9:16
From Perth
We hope to have costings finalised this week so that we can offer them for sale.
We got just on 5 degrees of neg camber, but we have also repositioned the pivot point of the lower control arm. I would expect 2.5-3 degrees neg without moving the lower control arm pivot point.
The red adjutment knob almost hits the inside of the shock tower....so we couldn't get much more neg on it!
Posted on: 2006/2/11 10:45
From Taupo New Zealand
nice job Mark. your car is a credit to you.
I won't be going to adjustables at this stage, will just weld a collar on the strut and space the spring seat up to the right height. semi adjustable I guess...
I have a question about rollcages- especially for the sunny guys- have you guys retained the dashboards in your cars? I am keeping the dashboard in my car, but it is impossible to get the front legs of the cage to follow the A-pillar, we are only allowed one bend in the front leg,so it can only follow the pillar for a small part before it must bend to clear the dash, at an angle so as to still have the foot foward enough not to make it hard to get in and out of the car... if you can understand what I'm trying to say!!!
Have you guys cut part of the dash away, or just bent the tube around the dash?
Cheers,
Morgan
Posted on: 2006/2/13 9:42
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Brisbane
Morgan, I tried to position the bend in the front legs so they go through the air vents.
Didn't quite work out so I cut away the dash from the air vents to the windscreen.
I put a picture in the photo album. (Don't know how to include in a topic )
Posted on: 2006/2/13 10:47
From Perth
Hey Morgan,
My dash is cut also to get the cage to follow the A pillar. To get the dash out though, we have to remove the windscreen! It's he only way that it will go in or out.....hence we have not (and have no plans) to remove it in the near future.
My cage is tagged in to the A Pillar also.
Cheers,
Mark.
Posted on: 2006/2/13 12:22
« 1 2 (3) 4 »
