1200 ute engine conversion HELP NEEDED!!
From sydney
i just bought a 1200 ute with a stock motor, but it does have a modified 5 speed box in it.
i want to know if there is any type of engine (turbo or non turbo) that will fit straight in without modifying the engine mounts?
i would like a little more power.
Thanks
Posted on: 2002/11/8 7:19
Re: 1200 ute engine conversion HELP NEEDED!!
From Melbourne, Australia
if its got the a-12 in it you can slot in an a-14 or a-15 for a bit more torque but less revs, it requires a plate to modify mount position but this just bolts on not welded or anything see other thread about a-14/15, ill be putting some info there tommorow with a diagram too
what year is your ute? if its after 80 you dont need this plate, motor will go straight in
Posted on: 2002/11/8 7:32
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From sydney
hi buddy,
i've got the a-12 engine in it now....
what datsun does the a-14 or a-15 come out of?
its a 1980!
Posted on: 2002/11/8 8:44
From sydney australia
okay,if you're in sydney (or close) that a14 i saw at pick & payless at blacktown was still there as of last monday.it's in a green sunny wagon & has a 4 speed still attached when i saw it.don't know a price,but this will drop straight into your ute.so i hope you're in nsw at least.oh yes,by the way,where are you?
Posted on: 2002/11/8 10:00
yeah best place to get a-14 is sunnys and best place to get a-15 is vanettes (some have a-12 some a-15)
basically a-14 is better for racing cause you get a balance of torque and high revving where a-15 is better for street cause you get that low down power but the motor wont rev out like the others
i know where there a-14 and a-15 in melb, you should put in your profile where you are to help us help you!
Posted on: 2002/11/8 14:05
1200 Coupe Rallycar
where the hell do you find a14 and 15 in melbourne? also what about radiators?
I almost bought a datsun 1200 coupe from the trading post last week for $300 because of the a14 and the radiator, th eguy just sold it. damn it.
Posted on: 2002/11/9 2:44
popped back into the pick & payless at blacktown again today,(just passing,saw the light on),& they have 2 a15's in vanettes as well as the a14,so you have a choice.there's also still the 1200 coupe & a 1000 wagon as well,plus plenty of stanzas & 200b's to get the brakes off of,& a scorched 1200 ute.don't know about melbourne,though.the address for anyone interested is tattersall rd,blacktown,on the corner,next to the sims metal yard.
Posted on: 2002/11/9 11:42
From Canberra, Australia
Oh yeah if you have a 1980 model 1200 then you wont need to put the adapter plates in to fit an A14/15 because these already had the newer engines.
Posted on: 2002/11/9 12:12
Mate that 1000 wagons not much good anymore! Didn't you see all they do is pile all the other sh@t in it now!
The 1000 has been there for ages I got a good tail light lamp off it! ( Suprisingly it was the side that I needed as one of mine had a few minor imperfections)
I can't belive how long they keep sh@t there for even if it has nothing on it!
I got the lens over 1 1/2 yrs ago now!
I keep telling Mick there to try and get some different ones, but I supose it is what is around at the time!
Posted on: 2002/11/9 12:31
From sydney
hey, i rang pick & payless and they told me they have a a-14 with 70,000k's on the clock for $250!
i might grab it...where abouts in sydney are ya? should hook up
Posted on: 2002/11/10 8:14
