(1) 2 3 »
What exhaust system are people running on their A series?
From melbourne VIC
Just wanted to know what exhaust system people are running to match the modifications on their A series.
I was planning on having an exhaust made up for my A12 which will shortly have high powered ignition, gx head, mild cam, single 32/36 dgav weber and 4-1 press bent extractors.
I wanted to have a dual 1.5 inch system made but was told that a single 2 inch system with a high flow muffler would be the best.
Your opinion and advice would be much appreciated.
thanks in advance
Posted on: 2006/2/20 13:28
Re: What exhaust system are people running on their A series?
From Perth
I used to run a 2.5" single system on my 1000 coupe with A12
Racecar runs a 2.5" single also with a single muffler (A15)
Posted on: 2006/2/20 13:39
From melbourne VIC
I had a mate who used twin V8 mufflers on his gemi and it sounded like a beast, but it did have alot of work done to it.
Has any1 had any experience with fitting these or hotdogs to their system, what did it sound like?
Posted on: 2006/2/20 13:53
From Christchurch. NZ
I use 2.25 inch exhaust with a single muffler, although it is quite loud and sounds like a rotor
Posted on: 2006/2/20 19:11
From Burbank, CA
2.5" from the stock header all through with a flowmaster muffler. It's pretty loud when you're on it, coasting it's quiet. Can't talk on the phone while driving as it's very loud :)
Performs good. Needs a header ( but waiting to go turbo )
Posted on: 2006/2/20 20:13
|||\ 81 KPB310 /|||
My stOCK a15 is running a 32/36 weber, pery 4-2-1 extractors and a 2 inch exhaust with a straught through resonator and the exhaust dumps under the LH rear door. Nice and loud and makes good flames on the limiter!
Posted on: 2006/2/20 23:07
From Brisbane, Australia
How have you got your rev limiter working?
Are they easy to source?
Posted on: 2006/2/21 2:49
From Townsville, Qld
I got a incomplete system off a friend who bought it at Jaycar. Wait a tic, it's a shift light kit but if you combine it with the universal high output ignition kit they have it can be a flat shifter. But electronics seem to just confuse the circuts outta me so I haven't fixed it, or my coupe
Posted on: 2006/2/21 3:07
ute had a 2 inch system, coupe has a 2.25 inch with 4 into 1 custom extractors and a tip.... 2 inch will be enough... 2.25 is loud (unwanted attention loud)
Posted on: 2006/2/21 7:28
it is a speed technology limiter, it drops every second spark or so....a soft cut limiter.
Posted on: 2006/2/21 10:07
(1) 2 3 »
