« 1 (2) 3 4 »
Re: A15
From Sydney Australia
the SR would b aproxximately 105kw stock, am i right? but form the figures given in this thread i would b getting that from an A15 after all the work converting it to turbo?
Although this may be true, remember that the SR would be 100% reliable and the A15 highly modified to get the same power, bringing with it a whole swag of problems.
Posted on: 2006/3/28 12:17
Re: A15
From adelaide
yep thats exactly the point i was getting at Ianey, with all them mods the reliability will reduce with the A15 but the SR would remain quite reliable.
so how much would the SR20DE conversion set me back guys does any body know?? cos i dont think im willing to pay 10big ones for the engine juuust yet
Posted on: 2006/3/28 12:58
Re: A15
a quarter of that'll get you a good quality a series motor that will suprise alot of people and also leave the car able to turn corners
Posted on: 2006/3/28 13:02
Re: A15
From adelaide
that sounds a lil better to b honest guys i just want to "surprise" my mate in his Vt commy, he talks it up like its some kind of supercar, i just wanna show him what a datto is made of..! any other suggestions of what engines to go for?
Posted on: 2006/3/28 13:13
Re: A15
From Brisbane, Narangba
If beating a VT is your only concern stay with the A-series. A nice worked up A-series will make him look silly in the first 100-200m and a good one will beat him across the line as he's on his last efforts to reel you in.
It will save you big time cost wise as remember its not just the engine you have to change. The whole balance of the car is changed to requiring suspension changes. Then consider diffs, brakes, custom tailshaft, wiring etc. Just bolt in a nice A-series and suprise yourself.
Posted on: 2006/3/28 13:21
Re: A15
depends on the engine ?? a few A series have gone from here cheap or for a couple thousand ready to bolt in .... check these for a couple examples :
A14 engine (bare)
+0.040 bore with new pistons and rings at beginning of year. Balanced with light flywheel incl 7/16" UNF flywheel bolts. Cosworth grind cam and reground followers. Oval port head with port work but more HP would be available with upgraded head. Good strong engine with 89 rwp. $650
It's a Datsun A15 engine with a list of engine modifications like,
New Bearings and Seals
11.5:1 Compression
JTS Alloy Head
Race Spec Valve Stem Seals
Double Valve Springs
54/86 Camshaft
Bosch High Rev Alternator
Perfectly Matched Twin Weber Carburettors (No Flat Spots, super Responsive)
Brand New 4 Into 1 Thermal Wrapped Extractors
Brand New High Energy Ignition System Consisting of a Bluebird Series 2 High Energy Electronic Distributor with Bosch HEC 715 Matched Coil, 8.0mm Leads and NGK BP5ES Spark Plugs
Brand New Facet Blue Electronic Fuel Pump into Holley Fuel Pressure Regulator
also in the deal is a reconditioned lancer brake booster ready to fit to a datsun 1200
asking $2700 for the complete engine and brake booster
either of these would 'suprise' your mate but probably won't blow his doors off in a straight line ..... but put it into some windy stuff and let the fun begin
Posted on: 2006/3/28 13:22
Re: A15
From adelaide
freak- i guess not the Vt alone is what i set out to beat but a major goal yes, it is just the standard 3.8 atm but will most probably b supercharged aswell so what would keep up? and to boofhead yes i have seen quite a few good deals pop up, and the A series does sound like the sensible choice but i just cant help but want the sr
Posted on: 2006/3/28 13:46
Re: A15
From SE Melbourne
Best way to get an SR would be to buy a 180SX I suppose, beat the VT easy....
If you really look into these conversions they are seriously hard, when you have to change your engine, suspension, drive train, fuel delivery, diff, transmission tunnel, brake balance...you get the idea, lots of work and 10K+ seems to be the idea. I can see 10K dissapearing real quick. I just added up what I'd spent on tools the last year.....$3000, to work on the A series! Modding cars is a rich mans hobby I think.
In fact the VT has probably been saftey recalled anyway at the moment
Posted on: 2006/3/28 14:18
Mildman, Datsunless
Re: A15
From Merimbula,NSW, Australia
IF YOU WANT THE SR20 YOUD BETTER BE RICH AND WILLING TO DO THE HARD YARDS I WANTED TO DO THE SAME BUT I WANTED THE DET SERIES AND IN AUS WOULD HAVE COSTED ME $12000 AS I COULD ONLY DO A BIT OF THE WORK MYSELF, MY ADVICE GET THE A15, A SUNNY 5 SPEED AND TRICK IT OUT A LITTLE THATS MY PLAN, AS SOMEONE SAID YOU MIGHT GET DRAGGED OFF ON A STAIHT BUT GET NEW SUSPENCION AND YOULL TAKE HIM ROUND THE BENDS, AND BY THE WAY TELL HIM COMMORDORES ARE FOR SISSYS WITH NOTHING BETTER TO DO THAN BURNOUTS
Posted on: 2006/3/28 15:13
Re: A15
From Burbank, CA
spend $2000 on suspension and brakes and beat him senseless in the mountains ;)
i'm serious, if you can drive, you'll destroy him with the stock engine and maybe a weber.
Posted on: 2006/3/29 5:07
|||\ 81 KPB310 /|||
« 1 (2) 3 4 »
