Browsing this Thread:
1 Anonymous Users
Re: flywheel? |
From Merimbula,NSW, Australia
damm, american dollars, #### u yanks and your high performence products
Posted on: 2006/4/19 4:02
DATSLIFE
Re: flywheel? |
From Burbank, CA
fidanza makes one too. It's probably USD.
you can get a stock flywheel down to 2/3 of it's weight safely, and less if you like excitement!
I suppose it's the old saying: speed costs/how fast do you want to go?
you can take weight off other places that the flywheel and have it do the same thing. Lighter crank pulley, use underdrive pulleys on the alternator and water pump.
The idea is to have less rotating mass, some places are cheaper than others to take it out of.
Posted on: 2006/4/19 4:05
|||\ 81 KPB310 /|||
Re: flywheel? |
From Canberra
3.7kg  Mine is 6kg and I wouldnt want it any lighter. 3.7 would be a bitch to drive on the street.
Posted on: 2006/4/19 10:17
Re: flywheel? |
From Burbank, CA
those aren't really for the 'street'
Posted on: 2006/4/19 17:19
|||\ 81 KPB310 /|||
Re: flywheel? |
From Millgrove Vic OZ
3.7 kg is fine on the street. The engine just slows quicker betweeen changes.
The only problem with the chrome moly wheels are they are made one piece and if the ring gear gets damaged its the whole flywheel shot..
Posted on: 2006/4/20 23:09
Cheers Feral
Re: flywheel? |
Quite a regular
From Mira Loma Ca. USA
I just had a flywheel lightened, it WAS 26LBS! Now down to 15.5 LBS. What a difference!!!
Posted on: 2006/4/20 23:30
1965 Datsun Fairlady 1500-A14 powered! 5 Speed All GX parts with twin Dellorto 40's 10:1 compression. 1976 B210 stock smogger with "dogleg" 5 speed and a ton of suspension work (coilovers, camber plates, etc. etc. etc.)
Re: flywheel? |
From Burbank, CA
on a datsun? must have been a CA A15 flywheel. I never got to weigh mine but mine was a mid 70's probably A14 and was pretty heavy.
Posted on: 2006/4/21 0:16
|||\ 81 KPB310 /|||
Re: flywheel? |
From SE Melbourne
By the way I found the weigh in figures for the A12 and A14 flywheels.
A12 = 9.6kg A14 = 9.9kg
I weighed them a couple of times to be sure...
Didn't realise they would be that heavy, also didn't realise there would be that little difference between the two.
Posted on: 2006/4/24 15:22
Mildman, Datsunless
