MT shifter bushings
From Burbank, CA
Is it just me or can we use the same shifter bushings as the 240z,280z, and 280zx?
Bushings like these?
Posted on: 2006/5/1 18:12
|||\ 81 KPB310 /|||
Re: MT shifter bushings
Quite a regular
From Mira Loma Ca. USA
pretty sure the Z shifter bushes are larger than the 1200/ B210 trans. shifter bushes. by the way sorry for not replying befor the show, as I was not near an Internet connection...
Posted on: 2006/5/2 3:47
1965 Datsun Fairlady 1500-A14 powered!
5 Speed All GX parts with twin Dellorto 40's
10:1 compression. 1976 B210 stock smogger with "dogleg" 5 speed and a ton of suspension work (coilovers, camber plates, etc. etc. etc.)
From Selah, Washington
Whats wrong with these?
BUSHINGS
Posted on: 2006/5/2 3:52
oops
Sorry
From Burbank, CA
Those don't fit all those models. I have a set of billet bushings for a 510 and they are totally different. those most recently referenced are visually like the ones for the 280zx.
what's wrong with those? nothing. doesn't come with the one for the bottom of the shifter and the delron is a better material.
i just like to keep an eye out for ways for us to get some cool parts too. and i probably need a set for my shifter, might as well, everything else's been replaced.
Posted on: 2006/5/2 4:11
|||\ 81 KPB310 /|||
From Stone Age somewhere in U.S.A.
those shifter bushings are still current part numbers, and are still available from your favorite Nissan dealer
the 2 side bushings that the pin goes through are part #32855-H1010
and the bottom one is part #32861-N4200
these fit all A series trans that I know of and almost everything else made from 74 through about 84, the do not work on the older 510, 610,710, Roadster, early Z models.
Posted on: 2006/5/2 6:09
From Sydney
One for the Aussie Datto know it all's , and maybe it's a stupid question... but is it the same part numbers down here as well?
Posted on: 2006/5/3 4:33
Every dog has it's day... except hyundai's.
From Burbank, CA
it probably is the same part #
Posted on: 2006/5/3 17:33
|||\ 81 KPB310 /|||
Most part numbers are the same for USA and Japan Domestic Market ... so I'd be surprised if the Aussie numbers are different.
32855-H1010 BUSH-CONTROL LEVER (need 2) $3.20 USD
32861-N4200 BUSH-CONTROL LEVER HEAD (need 1) $3.18 USD
I've never seen the latter one go bad, but the two side ones often do.
Try http://nissanparts.cc
Posted on: 2006/5/3 17:54
From Sydney
Thanks for that... mine side ones seem to have disintergrated.
Posted on: 2006/5/3 23:52
