Dogleg vs non-dogleg
From Huntington Beach, California
A friend of mine in New Zealand was wondering if there is a way to distinguish a std shift pattern box vs a dogleg shift box by looking at it from the outside.
Does anyone know if this is possible?
Posted on: 2006/5/29 1:50
Re: Dogleg vs non-dogleg
I don't think so, but move the lever to the left. If it meets spring pressure before fully reaching the left side, it is dogleg. Next, push fully left & foward & rotate input shaft. If the output shaft rotates the other way, it's still a dogleg.
In a standard shift 5 speed the spring will resist movement to the right & reverse is to the right & back.
If the box is a 56 series five speed, with ribs & the number 56A on the outside, it will be a dogleg.
63 series boxes are all standard shift I believe, so it's only the smooth case 60 series box that is in doubt, & 'most' of them seem to be standard shift types.
Does it have a hydraulic clutch, or cable? Hydraulic clutch systems were used on left drive models, & the most common source of these looks like being the US[?]. As far as I can tell, all of the US ones were conventional shift [overdrive] models.
Posted on: 2006/5/29 2:02
Love your Datsun.
Treat it well.
From Burbank, CA
isn't the 63a a dog leg overdrive 5 speed?
Posted on: 2006/5/29 2:07
|||\ 81 KPB310 /|||
Thanks Dodgeman.
The info is for a very good mate of mine in New Zealand. I don't know what box he is looking at, but I *assume* that the Oz/NZ models were mostly cable operated instead of hydraulically. (I've been wrong before, of course)
The shifter on my 63 series 5-spd box has a dogleg pattern on the gear shift knob, so now you have me wondering about that. I don't have it installed into anything, but I have always assumed it was a dogleg type. I have a 60A into my Morris Minor van, and it's definitely a dogleg.
Posted on: 2006/5/29 2:13
All of the Aussie & NZ models had a cable clutch operation, but the five speed was not offered in Australian models. I can't speak for NZ, but I think that they were the same,... no five speeds. All of the five speeds that exist here are imports, although I believe that some very late b310/ Sunny coupes that were sold here had them. This seems to be an aberration as the five speed is not in the Aussie parts book or workshop manual, so maybe a batch turned up in error like the A10 Stanza coupes.
I don't know about the dogleg 60 series box in your van, but it would seem obvious then that at least a few made it to the US, either in new cars, or as imports, you lucky SOB.
Anyway, if your unused box turns out to be a regular shift model, could you drop me a line as my brother allowed his dog in my car when he had it & the dog chewed my original B210 GX5 knob to death.
If the 63 box really IS a dogleg, then we both learned something.
Edit
210sleeper may have something there, but a dogleg overdrive seems a bit of a strange one as the rearward motion of the lear lever usually slides a synchro collar/ coupling sleve foward & the overdrive is in the extention housing, usually requiring a foward motion of the lever to engage. The 180B SSS [P610] had a five speed [dogleg?] 63 series box & I have a workshop manual, so I suppose I had better read it.
More Edit
The FS5W63A gearbox in the P610 SSS has first gear in the extention housing & it is an overdrive gearbox with direct in fourth. It also uses a dogleg pattern, so it would seem that your 63 series box could well be the same.
Posted on: 2006/5/29 2:47
Love your Datsun.
Treat it well.
From California
i don't have a detail shot of a gx-5 knob, but here's an l-series dog leg shift knob:
Posted on: 2006/5/29 5:15
Yes, that would probably serve very nicely, but I doubt that this is part of your private stash of parts, so now I need to see if I can buy one new somewhere.
Posted on: 2006/5/29 5:19
Love your Datsun.
Treat it well.
From California
o ye of little faith? ask and ye shall receive
Posted on: 2006/5/29 5:36
Here's another way to tell:
Is '63' cast into the side? It's a dogleg
Is it a ribbed casing 56a? It's a dogleg non-overdrive
Is '60' cast into the side, but the drain plug points straight back? it's a dogleg
I think Dman's method is the most foolproof, put it in gear and see how it rotates.
It will be harder to tell if it is a 4-speed and not a 5-speed.
63a B210 dogleg shift knob
60-L vs. 60A Comparo
63a gearbox
Doglegs: 56a vs 60L comparo
NZ 5-speed Utes
Posted on: 2006/5/29 6:05
Well here is that 'mate from New Zealand' turned up bright eyed and bushy tailed.
Thanks for the thread Mark and thanks for the info so far.
I'm after a std pattern with 5th as overdrive. I'm going to put it behind a A12 but am hoping to upgrade the engine to a A14/15.
A friend contacted and said he has a datto 5 sp so I went down there and figured if I turn it over by hand I should get some idea if its a dog leg or not by what way the output turns when I turn the input spline but...
If I put it in the forward left position I can't turn the spline, the same in the rear left and the rear right. In the forward and rear middle and the forward right I can turn it over but seems straight through so I guessed my figuring didn't stack up.
Its a smooth box and on the right side it has the nissan logo and '60'. On the top front of the bellhousing it has 'E B 0623764' that's the only codeing except #10 on the left side and #4 right rear.
here is a picture Datto box photo
Posted on: 2006/5/29 12:26
