wheres the boost
From south australia
i was thinking of giving a turbo a go with my set up as i allredy have the oil return line plumbed in to my sump my big question for the turbo a series gurus is where in the rev range dose the boost cut in with which turbo????
2500 to 3000 would be ideal to make it worth swaping my supercharger for.
Posted on: 2006/6/5 5:48
Re: wheres the boost
From brisbane
im guessing it would depend on what size turbo you get.... small one will kick in early, massive one will come in late...
Posted on: 2006/6/5 6:01
thats why i asked whhere with wat turbo
i am guessing the t28 would be the best choice for an injected a15
Posted on: 2006/6/5 6:03
From Melbourne Vic
t28 would be pretty big for a 1500cc. They come on full boost in the high 2000's rpm on a 2 litre. i'd say go a t25 or t25g. the t25g can make up to 180rwkw on an sr so you'd blow up an a15 long before the turbo ran out of breath. should be able to pick one up in reasonable condition pretty cheap. the t25 has less flow capacity but would be a blast to drive around with as the lag would be almost non existant. these are good for 140rwkw at least so once again, you'd blow up an a15 long before the turbo ran out of juice.
t25 = ca18det
t25g = sr20det
Posted on: 2006/6/5 7:15
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Not too shy to talk
From Sydney
i hav a gtir now and boost comes on at about 2800rpm. i no my mates old coup whitch had an a12 and it had a t28 wiych is standerd on the sr and his cut in at bourt 3400rpm. so the t28 should still boost but might hav bit more lag..
Posted on: 2006/6/5 7:51
R.I.P SR.1200
ill always remember ther fun times we had
lifes worth living wen u want 2 die sideways
From Christchurch NZ
Why?
Whats wrong with the supercharger? If you want more boost, run a bigger pulley.
Life's too short to wait for a turbo to spool up.
Posted on: 2006/6/5 9:30
Forced Induction!
From Brisbane
RB20 now your talking, i love Boost, EFI makes a big difference to a turbo car,
Posted on: 2006/6/5 11:51
nothing is rong with the super charger
i just like the idea of stageable boost and a turbo wont make as much noise as the supercharger dose it wont take much to plumb a turbo up to it and if it is not as good i will swap it back curiosity killed the cat i dont want to die wondering
Posted on: 2006/6/5 14:43
From brisbane, qld
maybe curiosity may kill the dat!??
Posted on: 2006/6/5 15:03
nah she be right mate
it will be straight on the dyno as soon as the conversion is done to set up the safe boost levels
Posted on: 2006/6/6 3:04
