gearbox
From Ipswich, QLD
hey all,
just wondering, my four speed is really loosey goosey and its getting hard to find the gears, is there any way i can tighten it up a lot???
thanks ty
Posted on: 2006/6/30 6:03
Re: gearbox
From Brisbane Australia
my guess is new g/stick bushes ?
cheers Ade
Posted on: 2006/6/30 9:01
Re: gearbox
Quite a regular
From Mira Loma Ca. USA
it depends on the "loosy" feel, it could be the plastic shifter bushings, that would make a sloppy shift. Or does it grind when shifting?
if so , it could be an adjustment on the slave cyl. or master. then again, it could be time for a 5 speed!!!
1965 Datsun Fairlady 1500-A14 powered!
5 Speed All GX parts with twin Dellorto 40's
10:1 compression. 1976 B210 stock smogger with "dogleg" 5 speed and a ton of suspension work (coilovers, camber plates, etc. etc. etc.)
Re: gearbox
From Newcastle (NSW)
In your gear box, there is a front section (including the bellhousing) a centre plate and a rear section. The centre plate has three grub screws for use with a flat blade screw driver. You should check that these haven't come loose and wound out. This can make it feel loose. You will need to drop the box out if you need to get a screw driver to them though..or the top one at least. The grub screw should not protrude from the case. But if you wind them in ALL the way, you won't be able to select any gear!
Posted on: 2006/6/30 10:17
Re: gearbox
From Ipswich, QLD
hmmm... it doesn't grind when shifting just feels like neutral in every gear, i can move the gear lever in each gear almost six inches sideways, like when in neutral.
Posted on: 2006/6/30 10:36
Re: gearbox
Gear lever pivot bushes, see your Datsun dealers parts counterman.
Part number 32855 H1010 is the most recent number in my 1200 parts book, so give it a try. You will need two of them, but buy four as a hedge against future availability.
They are the same bushes as used in the B310 Sunny sedan gearbox.
Posted on: 2006/6/30 10:51
Love your Datsun.
Treat it well.
Re: gearbox
Posted on: 2006/6/30 12:36
Re: gearbox
From Ipswich, QLD
THANKS MATE I'LL TRY THAT AND LET YOU KNOW HOW I GO
CHEERS TY
Posted on: 2006/6/30 12:59
Re: gearbox
From Burbank, CA
what does that big billet bushing go to i have one i thought it went to a 510. I need to know so i can sell it off, it's good for a quick $15 ;-0
Posted on: 2006/6/30 22:03
|||\ 81 KPB310 /|||
