Registered Users Contentmaster Usermaster
You can use *any* filter for any A-series engine, any year. The Datsun 1200 B110 has lots of room to fit the longer filters, and the smaller ones work too.
Some have a flat gasket like in the photo here, others use a smaller O-ring. Either kind works, but be sure to wipe off the flange well before putting the new filter on.
Here are some part numbers for A-series Oil Filters:
ELEMENT-oil filter, cartridge (threads: 3/4-16 UNF ID: 80.0 OD: 145.0) Nissan PN 15208-13212 or 15208-H1010 (from '72-2)
Other brands Tokio FL-208(Y) 1300, 1500 C-201 FRAM ExtraGuard PH3639 Fram Air Filters CA353 Fram Fuel Filters G3359 Fram FRAM Air Hog PRA353 Purolator #L30042 Deutsch #D601 Purolator PER42 (DATSUN,TOYOTA) Purolator L30042 Pennzoil PZ8 Champion PH2822,2825
newer A-engines 15208 - H8920 (threads: 3/4-16 UNF ID: 80.0 OD: 129.0) Tokio FL-208 C-208 CKO-1218 SP-842 FC 208 15208H8923 T-3135
NISSAN SUNNY,CHERRY (threads: 3/4-16 UNF ID: 86.0 OD: 100.0) FL-207 1515208H8916 15208-H8911 15208H8994 SP-929 5208H8917 15208H8912 15208H8905 15208H8904 15208H8903 15208H1011 15208H1010 Fram ExtraGuard PH3682 Fram ToughGuard TG3682 Fram DoubleGuard DG3682 Fram X2 XG3682 Purolator L24457 Pennzoil PZ27 Champion PH2827,2903 NISSAN,SUBARU AC Delco PF8903 Wix 51361 Champ PH2827 spin-on oil filter used on Nissan 200SX 4 cyl. 1.8L, 2.0L F.1.,& V6 3.0L F.1. engs., 300ZX V6 3.0L eng., M-10 Sedan 4 cyl. 2.0L F.1.eng, Maxima V6 3.0L F.1.eng, Micra 4 cyl, 1.2L eng., Pathfinder V6 3.0L F.1.eng.,Pickups V6 3.0L F.1.eng., Stanza 4 cyl. engs. Van 4 cyl. 2.4L F.1.eng.,Subaru 4 cyl. 1.6L & 1.8L, XT-6 Turbo 6 cyl. 3.0L Turbo. (Replaces: Nissan 15208-H8903; Subaru 15208-AA000) Equivalent: AC: PF1232 CHAMP: PH2827 FRAM: PH3682 MOBIL: MO-4457 MOTORCRAFT: FL-839 NAPA: 1361
B210, B310, F10 Fram ExtraGuard PH46 Purolator L10168 (Audi 5000 Turbo)
As always, YMMV. Check the threads and gasket carefully before fitting a filter. Make sure it fits, and check for leaks immediately after starting the engine.
Posted on: 2006/7/9 1:51
