Caliper questions
Not too shy to talk
From Palmdale, Ca
Has anyone out there tried mounting a wilwood or brembo universal caliper to a stock 1200 strut?
Posted on: 2006/7/11 21:01
Re: Caliper questions
From Las Vegas USA
Wilwood Dyna lites will fit over the solid rotor. What you will have to do is make a carrier. On our open wheel car it used VW Rabbit uprights , it was simply a matter of drilling holes in flat aluminum and milling out the proper shape for clearance.
Tom
Posted on: 2006/7/12 0:26
Not too shy to talk
From Palmdale, Ca
Thanks for the help, I think I might try that instead of doing an entire strut swap.
Posted on: 2006/7/12 5:18
From Burbank, CA
strut swaps aren't hard.
you can get better pads but the little solid rotor will get hot.
can't go wrong with the wilwoods.
Posted on: 2006/7/12 5:24
|||\ 81 KPB310 /|||
