« 1 (2) 3 »
Re: 2.6 astron into 1200
From Darwin NT
my freind had chrysler sigma's as paddik bashers they both had 2.6 nuffin went wrong except with the gearboxs they flogged those sigmas and they held up hate to say but they are a good motor
Posted on: 2006/7/23 12:42
From Brisbane
The 2.6L in my brothers 1985 import pajero is super thristy it can chew fuel thats for sure, its a 2.6L SOHC cam cross flow. Not sure which motors these are but it has done 250 000+ kms and hasnt had any problems, broke a timing chaing and some vavles from a over rev and thats been it.
Posted on: 2006/7/23 12:43
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
KA24de have been transplanted into the 1200 in the states. Good results and the 12v is also one to consider with a old rx7 turbo from the wreckers 190rwkws have been achieved with more to come.
All this on a 2 litre L series Hybrid setup and conversion.
http://zac510.ozdat.com/
the complete 2.4 ka24e or de will make more torque for sure.
Posted on: 2006/7/24 1:57
From Adelaide. SA
Sigma engines are getting old now and the alloy heads are tending to be soft now so be prepared to change a few heads! Cheers. Adam.
Posted on: 2006/7/24 3:00
From Townsville NQ
by littledarkone on 2006/7/23 20:03:59
I sense a Broadhurst influence here Ash....
Or a Sigma Pete influence......
Broadhurst influence, though nothing is set in stone of course
it's a $$$ thing, even though a KA24 would be nicer, why spend all that money & effort tracking one down when I could do a CA18DET?
the whole Stigma would likely be under $300 all told, what engine for under $300 installed into the car with a 5spd is going to be better? cubes & X flow make it better than an L series IMO, Z series are impossible to find, let alone a RWD KA24
I've seen carbied astron fagnas get decent economy too so they aren't that nasty on fuel.
Just a pissing in the wind thing atm, need to finish that bodywork & paint first.
Good to see it has been done though & isn't too off the wall...
Posted on: 2006/7/24 12:51
Z24 are cheap and ka24e head is cheaper and fits on using the dizzie from the z24 and use the cheap blubird or other l series box all match. Its all up to you.
Here pick a part have everything to make it happen on 50 dollar for a bare engine week.
All in all astron or Ka they are heavy anchors that will only assist in straight line action.
Posted on: 2006/7/25 15:12
From Townsville NQ
are they really that much heavier than say an L20B with 5spd though?
the other idea would be force feeding an A14 but that's likely to only come close to the stock output of an astron & will only have the 4spd still.
what do the Z & KA series donks come out in stock? Early Navaras?
Posted on: 2006/7/25 23:16
L series for turbo with z18 setup is straighforward.
KA and Z can be found in Ford corsair, nissan pintara, trx and the Z in commericals like vans, commuters and other utes etc.
Posted on: 2006/7/28 7:41
From Townsville NQ
I'll keep those in mind, however a later model injected Mitsu donk might be falling into my lap stupid cheap (for those familiar with Mitsu naming, single cam 16V 4G93).
It would be approx 100kw & return 8.0l/100km (the wife's lancer does) which would give me similar perfomance to a NA CA18, and being 1.8l I could force feed it later or replace it with the GSR lancer turbo version.
Posted on: 2006/7/28 8:32
good little engine the sohc 16v mitsu, very economical but needs all ecu and pollution gear etc. If you later decide on the ka24e or de you can get the crank pins machined to stroke it to 102mm and treated to take different rods and shorter pistons for a massive 2.6 litres 12 or 16v stroker.
Posted on: 2006/7/28 15:15
« 1 (2) 3 »
