« 1 2 (3) 4 5 »
Re: Who has the most powerfull boosted A-series?
Not too shy to talk
Hi dog160,
cold air induction is a good thing. Won't help the heat soak one little bit I'm afraid.
At any rate the power added will be lots of extra fun.
Posted on: 2006/7/24 7:06
From Canberra
mad bonnet scoops might
Posted on: 2006/7/24 7:11
Not too shy to talk
mad bonnet scoops are good, do that anyway!
cool air goes into hot turbo charger ----> hot air comes out and goes into motor.
Need to cool down the pressurised air in the pipe coming out of the turbo before it gets into the motor.
Posted on: 2006/7/24 9:09
From Melbourne, Australia
75rwkw was the official figure on mine
that was with 10psi from less than 3000rpm
through a 1.75" exhuast
and running out of fuel at 4000rpm (later found leaky fuel reg)
with some inlet air leaks
since then fuel pressure is up, exhaust is mandrel 2.5" and hopefully now i have found all the air leaks
unfortunately with someone rear ending the old shell (one week after new exhuast) and the fact that i've killed a set of rings running 16psi just recently... i've only driven it for one week it in the last 6 months
i'd love to dyno mine again properly but im still playing with things, and a proper tune up will be $900
project put another block in (a14 this time) starts this weekend, then hopefully i'll build a 15psi capable a15 block on the side
Posted on: 2006/7/24 13:10
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Newscastle, Australia
look Id be really surprised if your gonna get past 125 reliable rwhp out of a turbo A series anything else will be a grenade
Posted on: 2006/7/24 23:37
Dont die wondering.....
From Brisbane, Australia
Just because you gave up on the A-series. . .
If you feed it right. . .
Posted on: 2006/7/25 0:07
Yep I agree, a decent hp a series turbo setup which is reliable is totally possible.
Getting it to the ground on the other hand could be fun... I was breaking 4 speeds with a bog stock a12
Posted on: 2006/7/25 0:17
From In front, and pulling away.Sometimes around Sydney....ish!
My turbo experience previously was a blow thru weber on a G180 Isuzu in a Gemini coupe. Never dynoed (wasn't a lot of dyno's in those days!) but was heaps of fun! Couldn't go more than 12psi as it turned the carby into a sprinkler Now I'll try the suck thru, and when R-fast makes my new injection manifold I can step up to bigger numbers.
Posted on: 2006/7/25 0:43
Lifes good when your on BOOST!
From Brissy
i had a little trouble believing at first..
but after a ride i knew it felt pretty close to my old sr ute which had a lot more power..
if tuned and built right the A series @ 8 psi would be a reliable daily driver..
the driveline has to be modified to handle the extra power though...
Posted on: 2006/7/25 1:25
Well, the motor is in, and the Sunny is running! Booked for next Thursday on dyno for tune and to run some numbers, hope it isn't too embarassing!! Jeff, you would be proud!! IT LIVES!!
Posted on: 2006/8/16 12:12
« 1 2 (3) 4 5 »
