help on weber fuel presure please
From South Africa
hello there guys , good to be back after a while
can anybody please help with any information on as to what is the correct fuel pressure to be used on an 1400 with side draughts.
also as to what size fuel lines should be used, and if a regulater must be used ,also to what pressure should be used.
thanks guys
minnesh s/a.
Posted on: 2006/7/28 5:53
Re: help on weber fuel presure please
From Sydney
1.5 PSI but no more than 3 PSI.
Posted on: 2006/7/28 6:12
From South Africa
hello benny
thanks for the info
please can u tell me why because i have been told that i must have it between 4 and 7 psi
running at this we did have some problems with it flooding sometimes even at idle
can u also assist on weather a return pipe must be fitted grom the carb back to the tank. iwould really appreciate any input on this please
thanks
minnesh sa
Posted on: 2006/7/28 22:44
From South Africa
comon guys ahare some seckrets there.
thanks minnesh sa
Posted on: 2006/7/28 22:51
From Sydney, Australia
no secrets, webers expect the same fuel pressure that other carbies expect..no magic required.
I have only ever seen 0-5psi regulators used on weber setups. With 1.5-3psi being the common range. More than 4 psi and the needle and seats start leaking, raising the float level and flooding the engine.
Posted on: 2006/7/29 0:48
From Newscastle, Australia
Ive always run mine at between 1 to 1.5 psi no more...4-7 psi is way too much.
Posted on: 2006/7/29 1:57
Dont die wondering.....
The Weber book agrees. You need low pressure. Minnesh, you'd be better off listening to repair manuals rather than somebody's word. Just go to the library and check it out, or check the Weber web page.
Posted on: 2006/7/29 18:50
From South Africa
thanks there guys, will try it once again thanks
minnesh.
Posted on: 2006/7/30 19:17
