(1) 2 3 »
Gear stick bushes??
From Adelaide, SA
Hi everyone,
I need to change the bush that, as I have been told, is the reason my gear stick is so loose. Apparently there is a bush atop the gearbox that holds the lever solid? I was thinking of making one up rather than trying to soruce one, has anyone else done this I could really use their knowledge.
Thanks!
Go datsuns
Posted on: 2006/9/6 3:49
Re: Gear stick bushes??
From Wamboin near ACT(canberra)
i would also like sum info on this matter, as my gear stick moves around and its starting 2 drive me up the wall, i was going 2 try put sum washers on either side of the gear stick where the pin slots through, wat have other ppl done
Posted on: 2006/9/6 7:11
From SE Melbourne
I bought a set (of 2) from Nissan in Melboune recently for $10.85 each - unfortunately for you guys I installed them on the weekend....was thinking of measuring them...all they do is create an inteference fit between that big hole in your gearstick and the pin that goes through it....measure those two diameters and you'll be on the right track.
Posted on: 2006/9/6 7:17
Mildman, Datsunless
From Canberra
if its been without bushes for yonks the metal bits are probably worn heaps too. I've found getting a good gearstick as well as new bushes is better than just new bushes in a #### gearstick
Posted on: 2006/9/6 7:53
From Adelaide
going through the wreckers i found 2 brass bushes in a 1200 gearstick, i must say they work extreamly well. nice and tight the way most boys like it. dunno if there home made or what not but they look good. ill post a pic for yous to look at soon.
Posted on: 2006/9/6 7:54
classic not plastic
From Adelaide, SA the drift state
my mate went to star my car and it was in third and since its so loose he thought it was neutral. so were in adelaide can i source one
Posted on: 2006/9/6 8:12
From Central Vic
Have made them out of steel alloy and nylon
Alloy was great feel but you could feel the buzz every time you touched it
The nylon one's where best but need access to a lathe really to make
All else fails a tube and washer is a good temp solution
I found they where better as a press fit with grease on them
Posted on: 2006/9/6 9:00
to buy or not to buy???? OK
This is the reason I have five coupes
From SE Melbourne
The Nissan supplied ones are nylon. (in case you didn't know). I think the brass ones are a custom job.
Posted on: 2006/9/6 11:20
Mildman, Datsunless
From Sydney
i got a lathe at work i can use, if u's want get me the dimensions and ill knock some up, i was in cbc bearins the other day they have some realy strong and durable plastics for bush fabrication.
Posted on: 2006/9/6 11:23
They are just two plactic/nylon flanged bushes & they were still available new quite recently when I bought mine.
The Datsun 1000/1200 part number is NLA, but the B310 Sunny number is good & it's the same part.
I bought a couple of the little plastic sleves that go on the tip of the gearstick as well, although I have never seen a broken one of these.
Posted on: 2006/9/6 11:47
Love your Datsun.
Treat it well.
(1) 2 3 »
