I was talking general terms in RPM=HP. No replacement for displacement - why else do you think I have 3 liters of engine in my 510
Compression doesn't compromise driveability so much as it makes it harder to find fuel with a sufficient octane level to support it (which I suppose is a "driveability" problem as you
have to drive to places that carry adequate fuel). Low rpm torque (most equate this with driveability) is enhanced with higher C.R.
On these low RPM engines with big displacement: Trucks like Freightliners make 400hp and 1100+ ft-lbs of torque. Sure 400HP is a lot of HP, but for 8 liters of turbocharged engine it's
not so impressive. Works well for hauling loads becuase low RPM engines last longer than high RPM ones.
On this 355/6-71 equipped 1200. Are you building it or is it done? Any pictures of it? I had briefly considered a 400cid in my 1200, but decided I like not having to come to a complete
stop to make a corner. Would be fun in a straight line, though.
Dave Lum
'72 coupe getting 320hp SR20DET
'71 510 with 230hp VG30DE
www.datsuns.com
