Topgear wrote:
L18_B110 wrote:
I still have my first A series J pipe setup in a box under the house. It was totally ballistic - left my 116rwbhp L18 1200 for dead - like it was standing still!
with all this talk about turbo A series lately, I'm tempted to revive it to show what power you can get reliably
from a cheap and nasty setup - might see if I can find a $3-400 120Y or something
What turbo did you run on it and was it laggy??
MHI TC06-II which is apparently off a Mitsubishi Starion. draw thru 32/36 Weber on an internally stock A14 with 25/65 cam and ACL head saver shim to lower compression, water injection, 2.25" exhaust. it was on a J-pipe and from the turbo a cross pipe simply into the standard manifold - not pretty by any stretch of the imagination, but it was stupidly fast.
yes it was laggy as hell, but at 8000rpm and 10-11psi, you no longer cared!
only failures were:
- headgasket in the first few hours of trying to tune the thing...
- one piston after about a month I guess. undoubtedly due to all the detonation it had at first, which took us a while to get a handle on.
- one tailshaft and 4spd box in the same incident. unsure which one went first, but we went back and collected the remains of the tailshaft on the side of the highway, and it was screwed (twisted) up like it was a coke can...
- and finally the turbo itself, which needs a new bearing and seals.
the other turbo setup I did was an A12 with T25 on custom manifolds, draw thru 2" SU and 2.5" exhaust. standard internally except for a balance and milled pistons to lower CR. Can't remember how much we took off them. It was a better all-round package, but lacked the oomph of this TC06 setup.
