« 1 2 3 (4) 5 »
Re: A series top speed
beattie wrote:
105mph in the wags 100% stock A12 in 1000 wagon 4.37:1 and 1000 4spd.
Pretty scarry at that speed! If the speedo is acurite that is...it seems out though
The text says that the Van has a 'high speed cruise' of 81 Mph or 130 Kph. I think that this is more likely to be the maximum speed when fitted with the 4.375 to 1 diff & the 552mm diameter [550x12] rear tyres. [fronts were smaller at 500x12]
This wrings is out to about 6,000 rpm
Posted on: 2006/9/14 22:20
Love your Datsun.
Treat it well.
From sacramento california
when the turbo was runnning right i hit 125 then i blew the seal on my carb. ive had it to 130 mph with out even running the engine though hehe. in a semi trailer when i come to california from oregon. crazy truck driver+fast semi=get the hell out of the way.
Posted on: 2006/9/14 23:19
friends dont let friends drive stock!!!!
From Burbank, CA
you wouldn't even think a semi had gearing to get going that fast.
Posted on: 2006/9/15 0:27
|||\ 81 KPB310 /|||
From Bunbury Western Australia
bloody oath just need to sit by the great northern highway after dark here in WA to see how fast they go, theres no stopping them when they get moving!
We were traveling from Mt Newman to Bunbury and were sitting on 135kmph when a roadtrain past us!
We then decided it was best to pull over for the night
Posted on: 2006/9/15 23:43
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Not too shy to talk
From Adelaide, Australia
Got off the clock in my b110 coupe, fresh A15 - single 32/36 weber, 5 speed, exhaust, alloy rims etc. No doubt some speedo error - the dial was pointing at the h of "mph" at the bottom of the speedometer...maybe 190km/hr?
changed into 5th gear at 100mph (6000rpm) - road to Murray Bridge from Adelaide is perfect for speed runs.....3am to be safe.....
Posted on: 2006/9/16 7:06
From Geelong, Vic
my ute gets about 70-80 kph in 2nd gear, then i run out of road (paddock bomb)
Posted on: 2006/9/16 7:23
From Castro Valley,CA USA
Assuming my Autometer tach and math was right, I hit 6000 rpm in 5th which is around 115mph for me. I thought I was about to fly off the road or lose a fender or something.
Posted on: 2006/9/16 8:23
From Melbourne AUS
when the ute had the stock a12
best i saw was 130kph flat out in 4th
if i had another kilometer of road it might have gotten to 132 or 133 i reckon..
poor little a series
Posted on: 2006/9/16 8:51
1973 B110 A12
From Newscastle, Australia
205 (estimate) 8000 rpm in fifth in 63a box with 4.875 final ratio running 205 60 14 Yoko Advans...is there a formula or website to work this out exactly??
Posted on: 2006/9/16 10:32
Dont die wondering.....
http://www.datsuns.com/Tech/tech_gearing.htm
This dude has an assortment of calculations.
I guess this is relavent as well
http://www.datsuns.com/Tech/tech_aero.htm
Posted on: 2006/9/16 16:40
« 1 2 3 (4) 5 »
