webber carbs
does anyone know the float settings for these
thanks
Posted on: 2003/1/15 7:53
Re: webber carbs
From Sydney
different webers have different float levels..
What model webers are you refering to?
Cheers
Posted on: 2003/1/15 7:58
Re: webber carbs
If it's a downdraft carb, you generally set the floats perfectly level.
On the other hand, if you're serious about making your carb work better, get a book for the exact type of carb that you have -- it's easier to make them run worse than run better. The library can probably get the book you want if you're just gonna do it once.
Posted on: 2003/1/15 8:13
Re: webber carbs
Yea they are siddies i just put my motor back together and it ran like crap.Floats were full of petrol
Posted on: 2003/1/15 8:15
Re: webber carbs
From Forsby Finland
Buy yourself one of the best Weber/Dellorto books that I know at www.veloce.co.uk
How to build and powertune Weber & Dellorto!! It
Posted on: 2003/1/15 8:27
I am building a mean Datsun E10 racer , a15 turbocharged engine, aiming for 280hp....
Re: webber carbs
Quite a regular
From Pretoria - South Africa
Have to side with Datsun100ATurbo on that book, I've checked weber and delorto's lately with the specs for jetting etc on standard and modified engines and the book was worth it
Posted on: 2003/1/15 9:34
