Valvesizes in L-engine??
From Forsby Finland
Hi
What sizes are the valves in L-16 or L-18 heads?? I am looking for suitable 32mm exhaustvalves for my A15 head but I still haven
Posted on: 2003/1/16 14:30
I am building a mean Datsun E10 racer , a15 turbocharged engine, aiming for 280hp....
Re: Valvesizes in L-engine??
From Brisbane, Australia
Inlets are 42 or 44mm
Exhausts are 33 or 35mm
depending on the casting number. W53 head (1600/510) had the smaller valves (some others might also). casting mark is between #1 & 2 spark plugs.
Posted on: 2003/1/17 1:42
From Pakistan
does any one know ahy A series had smaller Exhaust valves while L series has bigger exhaust valves! any technical reasons if u have any.
barpk
Posted on: 2003/1/17 11:29
STRONG IS STRONGEST ALONE. PERIOD
From Forsby Finland
Thanx for the answer!! Maybe it
Posted on: 2003/1/17 12:01
From Melbourne, Australia
barpk i think you should re-read those values
and i still want to know whats involved in putting bigger valves in????????
Posted on: 2003/1/17 12:09
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Quite a regular
From Pretoria - South Africa
Yep, bigger valves does not really mean better flow and more HP, I know about a couple of guys that tried that (I'm not sure but i think it was 3-4 sizes bigger than standard) and created less power than a standard A-14 and they had webers, a custom exhaust etc
Posted on: 2003/1/17 12:24
From Pakistan
sorry for confusion!
what i meant is that in A series Exhaust valves r smaller then ITS intake Vlaves, but in L-seires Exhaust valves r larger then L-Series intake Vlaves, why is that?
barpk
Posted on: 2003/1/17 20:08
L-series valves are (as re-stated from above):
Inlets: 42mm
Exhausts: 33mm
or
Inlets: 44mm
Exhausts: 35mm
I don't know of any modern engines where the exhausts are bigger than the intakes (except possibly in 3-valve engines). The reason is that exhaust gas is exiting under pressure, and so requires a smaller valve. This allows more space for bigger intake valves, and helps keep the flow balanced.
Posted on: 2003/1/18 7:16
From Arlington, TX, USA
Inlets: 42mm
Exhausts: 33mm
Don't forget the "210" casting head (US L16 only) has even samller valves. They use 38mm intake valves, with 33mm exhaust. I think this head/valve combo came on L14's in other parts of the world.
Posted on: 2003/1/18 17:10
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
From Forsby Finland
Hi Michael!!
I need bigger exhaust valves because I am turbocharging my engine, otherwise exhaustgases hasn
Posted on: 2003/1/20 8:12
