« 1 (2) 3 »
Re: A Series powered boat (blew my outboard up!!!)
Quite a regular
From Kaiata
Webers or Holleys on bent eights,Four Amals or twin DCOE's on four cylinder mills Quote:
converted wrote:
ive seen webers in a near vertical position on V8 manifolds...what did they do in boats before injection??
Posted on: 2006/10/10 10:53
From sydney
Craig, maybe you could rig up something like this.
Posted on: 2006/10/10 11:23
From Townsville, Qld
what about using su stromberg type carbies?
Posted on: 2006/10/10 12:09
From Newscastle, Australia
hahahahahahahahaha Andy youre a classic!!! Where on earth do you find these photos!!! I could see my yellow race car mounted on a twin hull!!!
Dont die wondering.....
From Ipswich,QLD
You will need >>>>>>>
prop shaft >keywayed balanced and prop bolt $450+
floor coupling to run prop shaft through floor $350 + brass bushs machined to suit prop shaft .
alloy exhaust water cooled manifold a must ?$$$$
brass water pump for cooling system $200
Engine mounts you will have to make your self .
you will have to get the fibreglass made stronger around the engine area.
Id go a holden v6 efi set up should get one cheep enough and they already make water cooled exhaust manifolds for them .
Posted on: 2006/10/10 12:44
From Adelaide, Australia
120fly, do you have to marinate the engine like this or can you just use the engine the conventional way with rad etc.
Posted on: 2006/10/10 12:46
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
the only place you'd find such inventions... Tassie!
Well out in the sticks in tassie
Troy will know more, think he found it down in Roseberry or somewhere?
Why not just use a single 32/36? If its gota be downdraught that'd work fine surely...
cheers
Dave
Posted on: 2006/10/10 12:56
From Brisbane
a guy near work bought a 10ft alloy boat, it's a jet powered A14 motor, i'll get some piccy's up of it, he needs a stocko carby to suit, as it;s corroded.
Posted on: 2006/10/10 13:10
Quite a regular
From Kaiata
Holden V6 has for a jetboat,one vital ingredient ,TORQUE which an A series wil lnever produce .a Good boat motor......
Posted on: 2006/10/10 20:27
Quite a regular
From Perth, WA
Posted on: 2006/10/11 7:39
« 1 (2) 3 »
