Browsing this Thread:   3 Anonymous Users
Upgrading Radiator ..
From Lismore, NSW
Hey all, just wondering what is a cheap and simple radiator upgrade ?
Tye
Posted on: 2006/10/17 23:14
Re: Upgrading Radiator ..
From Las Vegas USA
B210 / your 120Y if your ute is A12 powered , for A14's unfortunatly I do not know.
Tom
Posted on: 2006/10/17 23:29
From Toowoomba Q Australia
There is a bluebird radiator and thermo fan on ebay at the moment. I don't know if it is possible to fit it to your car though. Maybe someone could confirm this?
Also I've heard a volvo 244 dl will do the job. Some mods though
Posted on: 2006/10/17 23:34
From Lismore, NSW
Its for an a15 .. Yeah im just after something that will keep it abit more cool on long trips, and somthing thats really easy to put it .
Tye
Posted on: 2006/10/18 0:26
Everyone upgrades to the gemini radiator or N14 Pulsar. A few of the members have done this conversion so they might be able to help...
Posted on: 2006/10/18 1:08
From Newscastle, Australia
this is easy....Gemini radiator just make up a few little brackets to fit to your radiator support panel and youre done in about 1 hour...dont even need to change your hoses...heaps of wreckers have them if youve paid more then $60 for an immaculate one with warranty youve paid too much.
Posted on: 2006/10/18 5:02
Dont die wondering.....
ive used gemini ones before, they do suffer from heat soak in trafic on hot days but what doesnt with no thermo fan.
I picked up a 1960s bluebird radiator from a club member modified to fit his sprint car, just giving it a clean and pressure test but thicker and a litlle bigger than stock but not as wide as gemini one. its 3 core to i think.
Gemi is good though on a15.
Posted on: 2006/10/18 12:26
yeah agreed thermo fan is a must.....
Posted on: 2006/10/18 13:43
From Adelaide, Australia
My partners car is a A14 with auto, i got a good gemi rad but seems to creep just over middle mark (maybe creeps a 1mm past in traffic) now we are getting into the warmer weather. Im seriously thinking of fitting a thermo fan for traffic, its got a brand new oval port head i dont want to kill. Its got a 170f thermostat in too.
Dont want to have to be in traffic in 40
Posted on: 2006/10/18 13:49
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Stray-ya
I have a pulsar radiator in my ute (A15) and it does a reasonable job, but it creeps up in traffic. Without a proper fan shroud this will probably happen whatever you put in, just cos the flow is not correct. thermo's will fix the prob though. Also make sure you have the right water pump. some (all?) of the A-15 ones have a shorter shaft and a smaller pulley diameter (i.e. run faster)
Posted on: 2006/10/19 1:54
