 Bottom   Previous Topic   Next Topic  Topic is Locked
Re: 1400 fiat motor????????
From Invercargill, New Zealand
I too had a Fiat 124 coupe - ALL standard 1608cc twin cam, twin side draft webers, 5 speed, 4 wheel discs and would redline in 5th. Not bad for a 1971 car - went fast and stopped quick - best standard car I ever owned. I'm a datto man now though because they cop the abuse and lurve it.
Posted on: 2002/9/22 12:46
From Arlington, TX, USA
datto_dave wrote:
do you have any ideas as to what i could do about the exhaust?
If the exhaust manifold does not hit the steering box you should have no trouble. There's really no difference which side of the car the exhaust comes out on. You can run the pipe down then over to the other side when it passes the transmission. sounds like a neat swap to me.
Posted on: 2003/1/19 23:22
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
From nsw,AUSTRALIA
if you have all the things you need and can do it ur self why not you can only find it has no power and if that is so then take it out and put the original back in as long as there isnt mager mods done to get it in there so bad that you cant put the old motor back in its fine so yer i hope you can understand that
Posted on: 2003/1/20 0:50
A14+1200 ute=dirty pants
Re: Gof or it
The fiat tc engine is a design made by famous Ferrari engineer and raced extensively by abarth fiats. Its the engine that the ca18 is based on cast steel but lightweight and strong. needs no pollution gear or catalyc crap. Very strong all round cheap and the 10:1 comp 1608cc version can be had with factory 43.5 inlet valves and 38 exhausts. After market valves are known to go up to 49mm thanks to the hemi chambered design. Fiats are not reliable and rust like the titanic, but engine and boxes are one of the toughest in the world. Reason for unreliabity is because they were assembled by depressed unhappy underpaid people in different parts were labour was cheap.
Turbo versions are known to go up to 400+ hp in the 2ltr versions with 2 valve heads before Rigoli went to the lancia 16v head
check out rigoli's site under projects.
The Fiat tc is light and compact its a winner for budget non computer set ups.
check out www.carsfromitaly.com
Posted on: 2003/1/21 6:34
Re: Gof or it
From Adelaide, Aust
Sorry dave i know its off your original question but i just have to ask seen as a few peoples have metioned about rigolis dato. Does anyone know what trans and what size stall is he running in it.
Posted on: 2003/1/21 10:11
It's a way of life
Re: Gof or it
From Sydney
Trimatic as for stall rpm i'll have to ask him when he gets back
Posted on: 2003/1/21 22:15
hey. can any1 tel me which engine is better to in in the datsun 120y.
an SR20DET
or V8
let me kno i wil get 1 soon
cant wait to build it up
Posted on: 2010/2/25 15:34
Hi ghost616, as your question is unrelated to the FIAT topic here, feel free to create a new topic for your question.
Posted on: 2010/2/25 20:05
« 1 (2)
 Topic is Locked
